Boiler Help Please
View the thread, titled "Boiler Help Please" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I
Ixape
Hello,
I have an ecotec pro 24.. It has three lights on the front of it. The lights are like this in the same order..
Red - Amber - Green
The green light always used to be on.. but now it isn't? Why? The boiler still functions
That green light that used to always be on, means that you had the preheat function activated. This means that the boiler constantly heated the small amount of water stored in your boiler, so that when you opened your tap you'd get hot water quicker.
This means that the boiler could be wasting gas by heating up water when you're not there, at night, etc.
Your saying you've not noticed any difference, if that is the case then there is nothing to worry about.
You can easily turn this function back on should you wish to do so.
Your installer should have explained all this to you.
Hello,
I've now noticed a difference after the boiler hasn't been in use for a few hours. If it's been used recently then there is really no difference. Please could you tell me how to switch it back on?
Thanks 🙂
Turn the hot water knob (top one I think) to maximum briefly and then back to the temperature you want, this should turn it back on again.
Reply to the thread, titled "Boiler Help Please" which is posted in Boiler Advice Forum on Plumbers Forums.
Ixape,
Ixape,
