boiler knocking
View the thread, titled "boiler knocking" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
Leadbetters
Hey does anyone know why this raven heat has started knocking,not all the time but is knocking.
I thought gas pressure but aint, then pump any ideas
Do you live in a hard water area? If so, the knocking is probably kettling due to the heat exchanger furring up. Adding Sentinel X200 will reduce this.
Would help to know mode; details leadbetters?? Knocking on hot water heating or both? etc...etc...🙂
Soz my previous post should have said "model" details 🙂
Is it a combi? AND is it heat or hydraulic related? If you extinguish the heat source does the knocking disapear?
More than likely, as meantioned B4 by Doitmyself, posible scale. Is it in a hard water area?
Reply to the thread, titled "boiler knocking" which is posted in Boiler Advice Forum on Plumbers Forums.
Leadbetters,
diamondgas,
