Boiler Manuals | Gas Boiler Manuals | Free Downloadable Boiler Manuals
View the thread, titled "Boiler Manuals | Gas Boiler Manuals | Free Downloadable Boiler Manuals" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Dan
Administrator
Staff member
Admin
Please Link To Any FREE Boiler Manuals
We'll try to get a bit of a database going here
[FONT=Arial, Helvetica, Verdana][DLMURL="http://www.mtsgroup.com/uk/ariston/"]Ariston Boilers[/DLMURL][/FONT]
[FONT=Arial, Helvetica, Verdana]Glow Worm Boilers[/FONT]
[FONT=Arial, Helvetica, Verdana]Worcester Boilers[/FONT]
[FONT=Arial, Helvetica, Verdana]Baxi/Potterton Boilers[/FONT]
[FONT=Arial, Helvetica, Verdana][DLMURL="http://www.ferroli.co.uk/index_main.html"]Ferroli Boilers[/DLMURL][/FONT]
[FONT=Arial, Helvetica, Verdana]Biasi Boilers[/FONT]
[FONT=Arial, Helvetica, Verdana]Vaillant Boilers[/FONT]
A few to start us off. 🙂
dan is it possible to thread common problems with boilers rather than try n search through all posts for a particular brand
Thats great dan
if your looking for common faults, the main problem is most the boilers operate the same, but do so with slight variations
for instance the high limit stat could be...
in the power line to the fan
in the power line to the fan pressure switch
in the power line to the thermostat
or in the line for the ignition system
without the manufacturers fault finding
guide, you could easily get lost... and
replace components that dont need to...
but that never happens lol
lol.... its very easy fixing boilers with 20grand of
kit in the back of the van... everyone else needs to
check and double check.
Regards
George
Hi dan ref boiler manuals, having problems downloading, can you help?
Tom, that is (can't use the appropriate words here!) fantastic!
you, sir, are an absolute star!
Tom you are a Star indeed, that is a very powerful tool you have just given all of us, thank you.
I have an elderly boiler and would like a manual to go with it.
Does anyone by any chance have a manual for Ideal E Type CF Series 3
models C.F 30/35, C.F 40/60 or C.F 60/80
Gas Appliance nos 41 399 23 , 41 399 24 or 41 399 25
This is model does not seem to be listed in the extensive library mentioned nearby in this list.
Thanks in advance
James
Why would you need a manual for that?
As basic as a boiler gets. All information you need is on the dataplate. Use your skill and engineering judgement for the rest.
Would anyone happen to have a free boiler user manual for a Range Powermaz 155x (with Pump/Prog/Hydro)? Help is greatly appreciated.
hi can any one help me i need a manual for a glow worm 240 bbu i am having some trouble with it i cant get it to come of pilot i have poer in and out stat and upto gas valve but nothing from the valve i think the valves faulty but i want to see if i am over looking something
thanks for the reply could it not be the stat not providing enough voltage up to the solenoid or are these a common thing on this model
i have never come accross this bbu before i have only wored on baxi bbus thansk for the assistance
If the gas valve is blue it has a 240v solenoid. Brown is 24v and has orange wires. Check the button is turned right round to on.
hi yes its the blue one and it turns alway round but only stays on pilot i tried a thermostat from a different boiler to see if it made a difference but it still did nothing i dont like condeming boilers if they can be repaired but it doesnt look good for this one the valves are obsolete which is why i am second guesing myself with the stat issue the customer said it did the same thing 8 years ago and it was the stat
You can get them on fleabay but some are expensive. I think some blue ones were 24v too. Can't remember, but all the 24v ones have bare connections for the wires.
If it has 24v across the solenoid terminals and the valve is not opening the solenoid is away or sometimes the valve may stick closed. Sometimes if it is sticking you can get it working again by giving it a tap. It won't last long tho.
Ariston boiler manuels Ariston
was going to throw a few in but just gone to that link its got them all.
but if you go to Ebay you can buy the lot for under £5 & put them on the PC I purchased one of thows small compact PC to take out on the Job its great for service gas pressures & combution analysis setup
Index
So plubstar your a star
Tom this great. saved the site but cant open the pdf files am i doing somethig wrong or maybe my pc is too slow.
Reply to the thread, titled "Boiler Manuals | Gas Boiler Manuals | Free Downloadable Boiler Manuals" which is posted in Boiler Advice Forum on Plumbers Forums.
Dan,
MZR,
