Nov 8, 2020
DIY or Homeowner
Hi all looking for some help with my boiler.
The pressure when cold sits around 0.8 to 1 bar but when the heating is on this is rising to near 3 bar on the gauge. I've had the expansion vessel re charged as it was reading 0 bar topped up to 1 bar but when releasing the pump from the valve water was coming out of the valve. Would this indicate that the expansion vessel has failed? The boiler is a viessmann vitodens 050-w
Still getting hot water and radiators but don't want to cause any further issues so keeping heating off.
Sounds like the diaphragm has failed. Will need a replacement expansion vessel and a gas engineer to repair.
Thank you for the information thought it might be going to get a replacement tomorrow and hopefully get the gas safe engineer in to fit this week
Reactions: SJB060685
The valves are on the bottom of the vessels, not a good idea because its where the condensation ends up , theres always some water comes out , but obviously I dont know how much came out . The valve wants removing and all the water drained out and then recharging. There is something else it maybe , but I cant go into this , your engineer should have an idea what to check next
Edit , sorry ignore valve on the bottom , I was thinking 100 . 050’s are on the top.
Engineer came out Friday drained the system topped up the vessel and when I tried the heating the same thing happened so hoping that replacing the expansion vessel sorts it. The boiler is just over 5yr old
