Boiler problem Worchester 240
View the thread, titled "Boiler problem Worchester 240" which is posted in Boiler Advice Forum on UK Plumbers Forums.
A
asd123
Hi all,
I have a problem with my gas boiler. Sometimes I see the boiler making noises when I use the hot water, the pressure increases to 1.5-2 bars and it switches itself off (i guess this is a safety feature). Then I wait until the pressure goes to its normal level (0.5 bars as far as I know) and I open the boiler to press the button in order to switch it on.
Any ideas whats wrong with it and can I fix it myself?
What you need is to get a Gas Safe Registered Engineer to have a look at your boiler. No you can't fix it yourself.
Reply to the thread, titled "Boiler problem Worchester 240" which is posted in Boiler Advice Forum on Plumbers Forums.
asd123,
Guest123,
