Boiler receiver wiring - Danfoss RX1
View the thread, titled "Boiler receiver wiring - Danfoss RX1" which is posted in Boiler Advice Forum on UK Plumbers Forums.
It used to work.
But the wire got tugged and pulled all the connectors out (except the grey one, that's still in the correct place).
I tried to wire it up again in the below pic but the hot water isn't coming on. Boiler is a Grant Vortex Pro External 26kW oil combi.
Since the below pics have been taken I have upped the pressure to 1.25, still doesn't work.
my rewiring of the receiver:
the boiler lights up, but when I run the hot water it doesn't fire up and remains cold:
when I hit the service switch the boiler fires up and seems fine:
What could have gone wrong here? Have I fried something inside the boiler? How should I troubleshoot this? It's a new boiler...
Leave the front off the rx1 so just the base plate is shown what does the boiler do ?
I'm just not sure what else to try. I'm not even sure if this wiring is right and the fitter won't get back in touch with me. The boiler fires up if I hit the test switch. I don't want to turn the central heating on cause its a new boiler and theres crud in the radiators.
Try putting the black with the browns does hw work then ?
Also why is there crud in the rads ?
The rads have never been flushed or had fernox. The house is mostly plastic 10mm pipework that was botched by a cowboy plumber. A lot of it needs to be completely repiped. I just don't want to risk damaging the new boiler. I will but the black with the browns now. thank you. oh also its a single channel receiver when apparently it should've been a dual channel, that was bodged too.
That’s easy enough if you want to swap to a dual channel programmer
Black is hot water
Grey heating
Brown lives
Blue neutral
Green earths
As someone trying to gain more knowledge and not understanding oil boilers, how does a single channel programmer (assuming for heating) bring on hot water? Or was it wired up incorrectly?
Hot water always on with oil combis it’s ideal / beneficial to have it timed to save oil eg not heating in the middle of the night / when no one’s in
Reply to the thread, titled "Boiler receiver wiring - Danfoss RX1" which is posted in Boiler Advice Forum on Plumbers Forums.
bunkotungus,
tamzbackforalook,
