View the thread, titled "Boiler recommendation?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
macka09
Hi all. Any recommendations for a 24kw combi and basic controls on a bit of a budget? Don't want anything cheap but rubbish.
7 day. Rf. preferably. Only ever used Worcester boilers with the dt10 or 20 I think.
I only fit Worcester usually so I'm competent with fitting there controls as most of them plug straight onto the boiler. Haven't really fitted anything else.
It depends on how tight the budget is, and your idea of "rubbish". You aren't going to get top of the line stuff at budget prices, so you have to make some trade-offs.
You could do worse than look at an Ideal Independent C24 or a Glowworm Flexicom CX24 with a Salus RT500RF programmable stat if money is really tight.
This guy doesn't even want a programmer, he's asked if he can just control it off the boiler.
Is it not against regs to not install temp control (stat) or are the boiler controls enough?
Strictly speaking you need a positive boiler interlock, but a simple hardwired roomstat can give you that. ALthough it may cost more in labour, cable and clips to fit a £10 hardwired stat compared to a cheap RF model.
Reply to the thread, titled "Boiler recommendation?" which is posted in Boiler Advice Forum on Plumbers Forums.
