boiler registration
View the thread, titled "boiler registration" which is posted in Boiler Advice Forum on UK Plumbers Forums.
lordyjordy111
Hi
can someone explain how the boiler registration scheme works
eg if i buy a worcester bosch from a merchants and that boiler has its own serial number
If i then fit the boiler who do i register the boiler with?? worcester bosch or gas safe or both
the reason i ask is a customer has bought a boiler and wants a labour price for fitting it
but what if that boiler has been bought of ebay/stolen off the back of a lorry.
If the boiler is being supplied by customer it is their responsibility to register with ,in this case worcester for the guarantee to correctly come into effect
The responsibility to register it with building control is always the customers,however if you are a member of a registration scheme ,such as gas safe run,you can offer to register it for them if you wish
If you are worried from a safety aspect were the boiler came from,ask to see the receipt ,other checks will be required,if it is un boxed,you are going to have to make sure designed for the correct fuel ie lpg/natural gas and have mi
As for if it was stolen or it's back ground,if the customer is suppling ,it is their responsibility that it came from a correct source,you could check the serial number with the manufacturers if you wished to double cover yourself
You will have to fill in the log book which is left with boiler
If you are really the customer asking the question and you have been offered a dodgy boiler,do not bother,as you could be easily caught if serial number is matched or faulty parts or bits missing
imho
Been there on that one some idiot wanted me to install a boiler he bought from Wickes that looked like it had been dropped from a height , now I wont install boilers supplied by customers due to agg
Reply to the thread, titled "boiler registration" which is posted in Boiler Advice Forum on Plumbers Forums.
lordyjordy111,
gasmarc,
