Boiler Serviced But Dirt In System?
View the thread, titled "Boiler Serviced But Dirt In System?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi All,
We have a Viessmann 222-F BT2B Combi Storage Boiler - it was installed in 2019 so about 6 years old. A Magnaclean Professional 2 Filter was fitted at time of boiler installation. A Power Flush was also done & a water softener fitted.
The boiler has been serviced every year without fail & the last service was about 3+ weeks ago. At time of servicing the Magnaclean filter is checked, cleaned & new Adey MC1+ Inhibitor always added.
We have 10 Radiators in the house - all double panel except one & six are less than a year old, two are about 2 years old, one about 8 years old, one about 15 years old & one about 20+ years old. There are 3 Towel Rads - two about 8 years old & one about 12 years old.
We used to find some sludge on the Magnaclean filter not an excessive but still a surprising amount considering mainly new main Rads, system had a power flush & yearly inhibitor added.
We had a boiler issue last week whereby it was not working & no hot water or heating. Viessmann sent an engineer round to fix & he changed a pump at the back of the bottom section & behind the top of the water storage tank. He still experienced some problems but was able to identify the issue as crud in the plate heat exchanger which, as a novice had me quite shocked.
I explained to him, that the Magnaclean 2 Pro was fitted just for this purpose to collect the sludge & debris so how could the Plate Heat Exchanger possibly be blocked & especially badly enough to cause the boiler to have issues & surely the Magnaclean Pro 2 would have have collected it as it was never fully packed with sludge on the magnet - it just does not nake sense to me at all.
He just said the filter collects some stuff but not all of it - but again, this did not make sense to me - I can understand if the there was so much sludge collected in the Magnaclean Pro 2 that there was no more room for it to collect any more of it but this was not the case & also, I was not expected much sludge at on a cleaned system with mainly new/newish rads.
The Viessmann Engineer said he did me favour as blockages in the boiler are not covered under warranty so I got lucky this time but probably not again if the same happens. The guy who does my servicing told me that if the Viessmann Engineer had not fixed the issue, it may have cost around £600-£700 to rectify which is awful lot.
I really wish to avoid this issue happening again & really want to look after my boiler so it is always in peak & healthy condition as it cost a lot of money & I expect repairs on it to be quite pricey (although it still has 4 years warranty remaining) but as mentioned, blockages are not covered.
I asked my service guy if one can do a Chemical Clean with say Sentinel X400 over say a week or so while the boiler is still in daily use & if easy to do - he was of the opinion that this & even a Power Flush will get the system "cleaner" (& no way to tell how much cleaner) but not fully clean? What are all your thoughts?
In view of this, what can be done to ensure this issue does not happen again & the plate heat exchanger (as well as the entire system) always stays clean?
Many Kind Thanks!
Thermal Imaging Of Some Rads:
We’re the radiators flushed before fitting as depending on manufacturer they leave a lot of rubbish in them
Worth definitely if you can dropping the water out and adding some x800 for a week then drain and re dose with Chems
Most chems manufacture well test the system water to see what’s going on eg sentinel etc
Hi ShaunCorbs,
Thanks for replying! There was a Power Flush & Magnacleanse done at time of boiler install but if you are referring to the newer radiators that were fitted recently, then no - the builders just took them out of the packaging & fitted them.
When you say dropping the water out, do you mean drain down the system? In my naivety, I presume you do not mean just putting the X800 in the system on it's own (no water?).
If you could be kind enough to explain to me a detailed step by exact step in novice & layman's terms that would be really helpful as I am just a homeowner. Is this something you recommend a novice can do?
What is the difference between X400 & X800 - I think I read somewhere that one of them needs special neutralisers afterwards to get rid of the last remnants of it otherwise it can damage the system?
This may be a bit of a daft question but would adding another Magnaclean Pro 2 help?
Many Thanks!
Hi All,
I came across this video by a plumber who was comparing filters & cleaners & as an experiment, he had a filter on the normal return pipe but also one on the flow pipe as well.
What he found was that the filter on the return pipe (as per standard installation) picked up the much smaller particles but surprisingly, the filter on the flow pipe picked up large chunks of debris - the type that would block up heat plate exchangers.
This has got me wondering since my Magnaclean Pro 2 caught sludge but not massively by any means - could it be that my boiler heat exchanger was blocked by debris that was in the flow pipe? This might explain why it got blocked?
I am wondering then, if it might be an idea to get another filter - something like the Magnaclean Micro fitted on the flow pipe so that way the Magnaclean Pro 2 can catch the smaller particles & the Micro 2 can catch the much larger ones as in the video posted below?
Just an idea & would welcome all your thoughts...
Many Thanks
View: https://www.youtube.com/watch?v=LpZZE5Lz3MA
Hi ShaunCorbs,
Many Thanks!
Was inhibitor added ?
Tbh have a look at plumberparts for a video on draining etc
Reply to the thread, titled "Boiler Serviced But Dirt In System?" which is posted in Boiler Advice Forum on Plumbers Forums.
Bazzy,
Bazzy,
