G
im in Dublin, Ireland, use the UK forum to get a more objective view 🙂
the amount of effort loading fuel every 20 or 30 minutes, monitoring the fire etc...
yes setup sounds very wrong.need a separate gravity circuit and central heating circuit as per the instructions that come with stove.regarding lukewarm water (stove can't keep up) you need a heat loading valve like esbe vtc 511.this will only allow stove to 'export' hot water into central heating system when it reaches >60 Celcius. Otherwise you will not only have cold rads but a cold stove which will lead to condensation of gasses and over time a clogged up chimney and danger of chimney fire.these valves make the world of difference.you also need a separate pump installed between stove and esbe to make it work well.suggest you get a plumber with qualification in wet back stoves to do proper install.
Thank God I sold my last one of those stoves two years ago, I am just outside Dublin sell and install solid fuel as well as other things heating related.
What similar stove would you have suggested?
Also what would you have charged to install, how is €400 a day cheap for a plumber and sidekick?
I got 5 quotes for this job and all suggested doing this way and they were guys with 25+ years of experience? are Irish plumbers that bad?
My plumber is coming back this evening and recons its air in the system or a broken valve, his words not mine so i will have to wait see, this did all work for the first two days but then the rads stopped heating up.
No I have seen some great Irish plumbers but unfortunately there really is a lot of awful ones too imho
