Booster pump on unvented hot water system
View the thread, titled "Booster pump on unvented hot water system" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
M
Masood
Need a little imaginative input here, please - custard has an unvented cylinder on ground floor, and a bathroom in the loft conversion. He had a new mains put in, and pressure both hot and cold are great throughout the house except for the loft bathroom. He would like a booster pump installed, but Stuart Turner are adamant that you mustn't pump out of an unvented cylinder. I can get around not being allowed to boost mains by installing a break tank on the cold, but what to do with the hot? Any ideas? Short of suggesting a small direct cylinder just serving that bathroom, I'm a bit stumped...
PS, I know that you can now buy 12l/min boosters that are legal on cold mains, but that won't really help him...
Thanks,
Masood
What is the pressure upstream of the PRV?
I don't know - I was there sorting out some problems with UFH fitted by his builder (who he's in dispute with), and he mentioned this in passing. He had a meeting to get to, and I had to get to another job, so it was just a very quick look and a request to have a think about a solution, no time to get the weir cup & pressure gauge out.
That said, opened hot & cold taps downstairs and on 1st floor bathroom just to get a feel for pressure, and it really is good pressure. Just the new bathroom at the top of the house that's a bit weedy.
Why can't CW break tank be made to feed both the cold & the cold feed into the un-vented ??
That was my first thought, but pressure downstairs is so strong that he may need pressure reducing valves downstairs. He was very reluctant to do this for no reason that I can think of (except maybe cost, but he's seriously loaded and I told him it would be particularly costly) Added bonus of this, of course is that the booster pump is downstairs, and not right next to the bedroom! (Loft bathroom is an ensuite)..
Upvote 0
If the pressure is good downstairs then on unvented it should be the same everywhere
There has to be a problem on pipe work on top floor
Upvote 0
He'll have around 3bar of pressure if the pressure into the house is above that. The PRV on the cylinder will limit to 3bar as we know. If he doesn't have 3bar + coming in, then you will have to think about a pumped accumalator possibly before the cylinder. The pump just increases the pressure in the accumalator at about 10litre per minute.
If he has 3bar + and isn't getting a good outlet in the loft, I would imagine it might be another issues. For every 10 meters of head, you lose 1 bar. How high is this loft?!
Possibly the pipe work is too small in loft, and it's starved by other outlets? Look at the more basic stuff first. So many times I've started to think outside the box, and then gone, oh it's switched off in the cupboad...etc etc.
Upvote 0
Yes, quite likely. Everything is now finished, tiled, hardwood floors, and so on. The guy is in dispute with the builder, so this was a little thinking outside the box solution required. It doesn't need a huge boost - the shower works, he'd like a little more than the gentle trickle that he currently gets..
Upvote 0
Check the obvious things first. It could be a check valve in the shower that's slowing it down. (on hose) Or a flow restrictor (on hose or on rose) seen that before.
Check all the basic stuff out. Might be an easy fix, and a chance to shine!
Upvote 0
Reply to the thread, titled "Booster pump on unvented hot water system" which is posted in Plumbing Advice for Any Other Country on Plumbers Forums.
Masood,
Dannypipe,
