Hello,
I'd like to pick some of your brains if I may?
Ive just replaced a kitchen tap in a ground floor flat and the customer is complaining that the hot flow is a trickle, which it is. It was before too.
They have an open vented system with the hot cylinder on the floor in a cupboard off the kitchen and the cold cistern on a platform just above with its base at maybe 1.2m from the floor. The base of the cistern is only about a foot or so above the level of the top of the kitchen tap so no surprises why there's crap pressure.
What I want to know is what would be the best type of pump to put on the hot from the cyclinder to boost the pressure? I'm thinking a negative head pump but just wanted to bounce it off you guys with more experience as I've not fitted a pump before.
