Bypassing faulty room stat
View the thread, titled "Bypassing faulty room stat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt0029
If removing the two wires from the room stat that connect to the boiler to place a link in the room stat terminals in the boiler. As I think a faulty room stat is stopping the boiler from firing. Is it acceptable to leave the link in till I can pop back with a new stat? Bad practice I guess
leave them outside of the boiler case in a choc block and put a link in where they were
What makes you think the room stat is at fault? Link them out, just connect them into one room stat terminal, and test fire boiler before purchasing new room stat. Make sure that you link the correct wires!
This may all seem obvious, but I fear that the OP's questions suggest a limited range of experience.
Reply to the thread, titled "Bypassing faulty room stat" which is posted in UK Plumbers Forums on Plumbers Forums.
Matt0029,
firemant,
