Oct 17, 2017
97
10
Somerest
DIY or Homeowner
Hi all, so things are coming on now at last!
New 250 cylinder in loft all pretty much plumbed in.
F+E tank binned off, new ups pump, 2 new zone valves imstalled...
Now im up to wiring up, have done the immersion, so we have hot water, ive wired in the dual stat. I have me head roughly into what i think is correct...
Last night when i was pressing the advance on the controller, noet was happening....no red light to indicate and no boiler fire....
i did see when i moved the contoller, there are some jumper links on the back of the unit...do i need to move these when going from y to s paln??
I think
Turn them on to timed then try advance
Pump Shouldn’t be running as the system is off eg timer is off
Yes, that works!
pump runs, but boiler not firing....
Temp at 76 but all pipes cold...
Im not sure if the new pipework is correct...
