View the thread, titled "Can I fit a pan connector from toilet to sani" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Ah the dreaded Turboflush! Now this is going to sound really daft but if the end of the wires had what looks like metal lugs on the end then cut them off, bare back the insulation, twist the bare wires (as you would when wiring a plug) and then rewire into the switched spur you have there.
Thanks for your replies!
Yes they did have metal lugs which I thought were to keep all the strands together clean. Could this be my issue then ? And was I meant to strip them I didn’t see anything in the booklet.
I have had to leave site to attend another job but will try this tomorrow or Monday
No you weren't told to strip the wires back and even though it makes no sense it can work.
Another possibility is that water is being syphoned out when the motor stops so water level is low which doesn't help.
When you go back flush the toilet and wait until the cistern refills then if it hasn't burst into life give the left hand side of the tank a gentle kick. If it starts then call the warranty guys in.
That’s some awesome knowledge mate
I’m planning on visiting tomorrow so will update 😀
Thanks for the photos they made life easier.
One thing though, the discharge elbow is rubber as is the Grey connecter you used to join it to the solvent weld pipe, did you use a short length of pipe inbetween, rubber on rubber isn`t a good joint.
Yes so the discharge elbow and grey coupling have a piece of 30mm pipe inside to ensure jubilee clips can be nice and tight.
Okay so I’m back and cut the wires and it’s all switched on. It doesn’t kick in when the basin is on ?! So can flud if the tap is left running but it’s kicking In when I flush it now 😕
After more tests. I run the basin tap which is connected into lower outlet and the sani will not pump away. It starts to fill up the pan. If I then immediately after flush the toilet the sani does not pump away.
It should
Sounds like pressure switch misbehaving
Could be damaged in transit
Isolate all water
Call the warranty phone number
It should
Isolate all water
Appreciate all the help anyway. I’m going to return it and go back with a replacement Monday. Will let you know 🙄
Nothing optimistic about it harvest, fitted loads of customer supplied pumps from fleabay which don`t work, even had a 10yr old pump where customer had been told it was only 2yr old and had been hardly used! Robbing bar stewards out there.
The optimistic wasn’t about you mate. It was about EBay. Sold a 1 month old Bristan tap on eBay with a warranty card. They then decided they had a fault with it after 3 weeks. I explained they needed to go to Bristan. EBay automatically gave them a refund from my account without even talking to me. I hate EBay. The seller has no protection what so ever.
Ah sorry, mis read that then.
what tap?
Reply to the thread, titled "Can I fit a pan connector from toilet to sani" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread starter
Joined
Location
London and surrounding
General Plumber
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Thread Tags
Tags Tags
toilet
J murton,
ShaunCorbs,
