E
EBrant
Hello
Can some one please help me with the following question, thanks 🙂
In a standard 2 pipe domestic central heating system I understand normally the 22mm feed and return would go around the rads in a single circuit as it were. Imagine on a drawing the boiler is on the left and the rads are all on the right.
Now what if the drawing has the boiler in the middle and the rads on the left and right, before you T off the 22mm feed down to 15mm to any rads (last rad being 22mm to 15mm elbow rather than T) can you T the actual feed and return pipe itself e.g. 22mm to 22mm T piece than go around the rads in the normal way?
The reason I ask it in my house it would be far more convenient to run the pipe work like this. I am not proposing any valves (e.g. zoning) in the 22mm pipes and I am assuming (this is the main point) that the water will just as likely then left and right when it meets the T? unless all the TVR are turned off, in which case should I not fit a TVR to the last rad in each circuit
Thanks all
E Brant
Thanks all
E Brant
