Can't stop tiny trickle into Pan
View the thread, titled "Can't stop tiny trickle into Pan" which is posted in UK Plumbers Forums on UK Plumbers Forums.
So what's your answer to water still running if tank is empty and water off ??
Please don`t do a politician on me by answering a question with a question and jumping forward 20 posts to a dry cistern. I`m trying to find out if you know something I don`t as I attend to macerators which according to customers are self ativating when it`s always down to a trickle of water from cistern to pan which is stopped by either cleaning or replacing the syhon valve or in rare instances a crack in the ceramics.
That's me getting in some practice for upcoming elections, think this is some sort of wined up by OP , reply was asking if what he has bought complies with standards, cos I had same problem with imported wc and water board would-not permit any of it to be connected, unless you were off main drainage / water supply
Where does the OP live, if in London I want to come over and see this badboy in person.. I'll get my face in the paper, become famous and rich beyond my wildest dreams 🙂 mwah ha ha haaaaaaaa
Seriously though, allanwhyte77, where are you based? If the water has been properly isolated and the cistern is dry and you've emptied the pan it's pretty miraculous that water is still leaking into the pan.
Disconnect the water inlet pipe (while still isolated) and see if that's letting by. I would normally assume the siphon (flush valve) to be the culprit but if the cistern is dry then *shrugs shoulders* something strange is happening at the ranch.
Are you sure there is no residual water between the cistern/pan that is clearing itself very slowly??? Maybe around the doughnut or something.
Have you looked up?
This thread reminds me of the miracle of peckham episode of only fools when Del convinces everyone the virgin mary statue cries when really it's a leak dripping down from the ceiling
take the cisten of the pan prop it up so its sitting level a workmate is perfect then fill with water leave for a couple of hours and see it the water is coming out of the inside or outside of the bottom of the connectorout side its not sealed properly inside it faulty overtightening can distort the seatings
That's my thought as well. Carp Chinese casting causing water to lay somewhere and slowly leak out.
Reply to the thread, titled "Can't stop tiny trickle into Pan" which is posted in UK Plumbers Forums on Plumbers Forums.
allanwhyte77,
Mike Jackson,
