yes hat makes sense but I have to get the water around the system in the first place.I think between us we have arrived at the problem. My concern now though is as I mentioned above are the existing rads at ∆T 60°c, if so the flow temperature will need to be around 90°c to give a rad MWT temperature of 80°c and full out put.
You are magic and clever so thank you.Yes I agree completely. However I suggest separation, pumps in series is not always going to work.
That is also my logic and I thank you for your help. If the boiler produces hot water and the circulatory systemAfter the external heating plate heat exchanger which will need to be added
I have a qualified engineer arriving tomorrow afternoon. Thank you for your input! John.
Close enough
As you said close enough mate but I must add if the secondary side is staying open vented then pump in that image is not situated ideally. One would need it to be V,C,P on the flow out on secondary side.
Not sure but will check out. There appears to be a vast misunderstanding what the roles are between plumbers, heating engineers,Do they do commercial heating systems ?
If it’s a combi it’s sealed or they’ve linked the pressure switch out as navs can’t be run ov
central heating specialists.
Yes, life is full of givers and takers. I find it easier to be a giver as I sleep soundly.We do this because we are passionate about our industry, unfortunately for your friend he employed the services of someone who quite frankly doesn't know the basics and as Shaun mentioned before that's damaging.
Well done for sorting out my problem.
£2400 supply and fit but did not supply commission document or make the system work. They said that the lackWe've arrived at the problem and can advise on the possible solutions but ultimately it's down to you to find a suitable engineer. Unfortunately knowledge and experience comes at a price, something you and your friend have now discovered.
Can I ask, you said your friend was charged just over 2k, was that supply and fit?
£2400 to supply, fit and commission a boiler is really quite low, let alone not sign the necessary paperwork. I can tell you right here and right now that £1300 on new trv's will not solve your issue and had you agreed to that you would still be where you are now. These guys who undertook the work really don't know what they're on about and I genuinely feel your pain.
We've given you all the information you need to move forward. Make sure the new technician that attends is fully aware of the problem and everything we have discussed and hopefully they get you sorted.
Note for the future, an installer/engineer who charges pennies for a job should not be trusted.
Thanks for that, it makes sense. May I ask what is the reference LLH and CCt's please. I had a local centralBy the sounds of it the residual pump head after pumping through the boiler heat exchanger is not enough to overcome your index circuit resistance which is why you're experiencing the problems you are. You could either add a LLH and additional correctly sized pump or CCT's and pump. If the secondary side is the same flow rate as the boiler either will work, you just need additional pressure to circulate around the system. Adding pumps in series is not a good idea.
He said that the boiler was capable at 4okw output for the need. he did agree that the output of the inbuiltThanks for that, it makes sense. May I ask what is the reference LLH and CCt's please. I had a local central
heating engineer around to asses the system to add extra whoomph to the system but after an initial visit he is not returning
my calls. They are a good working family, even the young children are doing their bit for the pub/restaurant and I would
like to see them sorted. Cheers, John.
Reply to the thread, titled "Central heating not circulating after New Navien Combi fitted to Santon Premier system." which is posted in Central Heating Forum on Plumbers Forums.
