changing a gas boiler
View the thread, titled "changing a gas boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
A
ajoint
if you change a gas boiler combi 4 combi do you have to drain down the heating side or just drain down half way?also adding inhibitor where is the best way to add inhibitor,thanks,ajoint
Don't worry about the heating. Just drain the cold water out of the mains. Leave cold tap on. Should take about..........forever
Scary question. When cutting a gas pipe do I need to turn off the gas or shall I carry on smoking this cigarette ???
Reply to the thread, titled "changing a gas boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
ajoint,
AWheating,
