Hi - this maybe a bit basic, but I have a clickable sink plug that is broken and needs replacing. The part is a BRISTAN, part number W BSN CLICK C.
See attached Image.
I found out this is now discontinued, and the new part needs the waste pipe to be changed as well. The new BRISTAN part code is W BASIN 08 C, as you can see here:
https://www.bristandepot.co.uk/plumbing/W_BASIN08_C.JPG
This is a different job to a simple like for like replacement, and I am wondering:
1. Are there any non BRISTAN parts that could just slot in, like the existing part?
2. If not, is it easy to remove the pedestal and change?
3. And to put a seal around the area I have arrowed, should I use LSX or something else?
Thanks,
Alex
See attached Image.
Thanks,
Alex
