Easier said then done. But take your time and don't rush it. Try and understand exactly what you are aiming for in terms of what to
connect and where and you should be fine. Even if you do struggle the customer will see that you've tried your best and sometimes that's all we can do!
dont offer to install the nouvelle in their other place, you,ll be there till next sat setting it up and if you damage the oven stat, it'll be over £400 for a new one, if you can get one 🙂 otherwise they are scrap value down here, working or not
not sure if we are gettiint the job to fit the nouvelle but if my boss says yes doesnt leave me with much choice.
heat leak rad is basically a bypass rad should have two lockshields on it and always open its for uncontrollable heat sources like coal and solid fuel which may have been there before the existing gas aga
Be on the 28s too. Easiest thing to do is jump on to 28s in ac with F&R and then link out 28 to 22 above old boiler so grav flow into 22 flow and 28 grav on to 22 ret. easy but u waste scrap [emoji80]
