charging for jobs
View the thread, titled "charging for jobs" which is posted in General Plumbing Jobs Discussion on UK Plumbers Forums.
K
Kyle87
im a novice in the plumbing world but i must say im learning fast.
my ambition is to be a self employed plumber......and trust me i will achieve this and do everythingican to become successful and i dont care what people say ie. 'why do ya want to be a plumber theres no work out there' well my answer to that is that there is work out there just not for you because instead of looking for it, you here moaning to me about the lack of it. rant over lol.
so my questions for today are.....how do you price your jobs. how much? what for and why
obviousily the subject of 'how much do you earn is sensitive
id like to be talked through a few scenarios
some one calls you to come out and price a job up.....do you charge for the quote
when you do the job do you charge per hour plus parts
when someone calls in an emergency.....do you apply a callout fee if your there for 5 mins
when someone calls in an emergency......do you apply callout charge and hourly rate if your there for a few hours.
im learning more about the trade every day and cant get enough.....
please can can you provide me with as much info as possible on the matter to help me build a realistic picture of how im going to do it all in a few years.
many thanks
Bit tongue in cheek but i'll answer them
so my questions for today are.....how do you price your jobs. Usually time based with a bit of the going rate in there how much? depends on the work and if i want it what for to keep the wolf from the door and why i sometimes ask myself the same thing!
I'd love that one to be a reality but it won't happen. Depends on the sector you work in and the type of work you do. You'll probably spend as much time pricing jobs for free with no results than you will spend actually doing the ones you get.
Usually a fixed price but some on an hourly rate. Again it depends on the type of work. Some work by its nature cannot be fixed price. The sensible ones (customers) with jobbing stuff would usually be cheaper with an hourly rate. I don't have time to mess around so its in and out job done and i'm fast but if they don't know me they (for obvious reasons) go for a fixed price. I don't mind either way.
I don't do call outs but set a minimum charge if you do.
As above. If it is an out of hours call take a call out charge which covers the first 30 minutes or hour depending how you want to work it then your (premium) rate. Calls during the day usually no call out but work it to suit yourself and your market.
I had enough years ago but i'm still at it!
You'll learn :wink:
many thanks
so my questions for today are.....how do you price your jobs. how much? what for and why Depends on the size of the job, it's either hourly rate for small jobs or day rate for larger jobs. My rates are twice what a lot of local guys are but I'm more than twice as fast so the customer is getting a better deal with me.
some one calls you to come out and price a job up.....do you charge for the quote As Tamz said it's not possible to charge for quotes but be strict on your definition of a quote. I had a customer a couple of weeks ago ask me to give her a quote to repair her heating system and I told her that it would cost her £40. She queried this and asked why i didn't give free quotes but I advised her that it wasn't a quote as I needed to spendmy time diagnosing the fault before a could give a cost.
when you do the job do you charge per hour plus parts and a percentage on top of parts to cover call backs in case of manufacturing faults.
when someone calls in an emergency.....do you apply a callout fee if your there for 5 mins Yes
when someone calls in an emergency......do you apply callout charge and hourly rate if your there for a few hours. Yes
many thanks
You come across as a bit cocky in your posting, be wary of this attitude in the real world as it will alienate you from merchants and other plumbers and you nver know when you are going to need their help.
So you're going to hoover up all the work we can't be bothered to chase and set the plumbing world alight but only after we've told you how much we charge? That's a classic lol
Good luck.
some one calls you to come out and price a job up.....do you charge for the quote No
when you do the job do you charge per hour plus parts Depends on the job, somethings like servicing are fixed rates others an hourly rate, parts always extra
when someone calls in an emergency.....do you apply a callout fee if your there for 5 mins I should but depending on who and where mostly don't charge
when someone calls in an emergency......do you apply callout charge and hourly rate if your there for a few hours. Just nomal charge
many thanks
As above
[TABLE="class: data_table single"]
[TR]
[TH]charges
[/TH]
[TH]Mon-Friday
7am-6pm
[/TH]
[TH]Mon-Friday
6pm-12am[/TH]
[TH]Saturday
7am-12am[/TH]
[TH]Sunday
7am-12am[/TH]
[TH]Mon-Sunday
12am-7am[/TH]
[/TR]
[TR]
[TD]are per hour[/TD]
[TD]£80[/TD]
[TD]£130[/TD]
[TD]£130[/TD]
[TD]£140[/TD]
[TD]£200[/TD]
[/TR]
[/TABLE]
One hour minimum charge then in 15 minute units. Some work can be carried out on Estimate/Fixed Price.
    • Airlocks
    • Ball values
    • Bathroom refurbishment
    • Bidets
    • Blocked toilets, sinks pipes & drains
    • Burst pipes
    • Floods
    • Gutters & downpipes
    • Hot cylinder installations
    • Hot water problems
    • Immersion heaters
    • Kitchen refurbishment
    • Leaks
    • Overflows
    • Pipework replacement
    • Plumbing installations
    • Pumps
    • Radiator & values
    • Repairs
    • Saniflo repairs & installs
    • Showers & pressure adjustments
    • Stopcocks
    • Tap repairs & installations
    • Thermostat problems
    • Toilet repairs & installs
    • Unvented water cylinders
    • Waste disposals
    • Water heater repairs &installs
    • Water tank installs
    • Wet room refurbishment
I would set your charges around the above, should be on target for £60,000 by the end of the month
[TR]
[TH]charges[/TH]
[TH]Mon-Friday
7am-6pm[/TH]
[TH]Mon-Friday
6pm-12am[/TH]
[TH]Saturday
7am-12am[/TH]
[TH]Sunday
7am-12am[/TH]
[TH]Mon-Sunday
12am-7am[/TH]
[/TR]
[TR]
[TD]£80[/TD]
[TD]£130[/TD]
[TD]£130[/TD]
[TD]£140[/TD]
[TD]£200[/TD]
[/TR]
[/TABLE]
    • Airlocks
    • Ball values
    • Bidets
    • Burst pipes
    • Floods
    • Immersion heaters
    • Leaks
    • Overflows
    • Pumps
    • Radiator & values
    • Repairs
    • Stopcocks
    • Waste disposals
Thanks ecowarm, I can now set my prices accordingly 😛
[TR]
[TH]charges
[/TH]
[TH]Mon-Friday
7am-6pm
[/TH]
[TH]Mon-Friday
6pm-12am
[/TH]
[TH]Saturday
7am-12am
[/TH]
[TH]Sunday
7am-12am
[/TH]
[TH]Mon-Sunday
12am-7am
[/TH]
[/TR]
[TR]
[TD]are per hour
[/TD]
[TD]£80
[/TD]
[TD]£130
[/TD]
[TD]£130
[/TD]
[TD]£140
[/TD]
[TD]£200
[/TD]
[/TR]
[/TABLE]
    • Airlocks
    • Ball values
    • Bidets
    • Burst pipes
    • Floods
    • Immersion heaters
    • Leaks
    • Overflows
    • Pumps
    • Radiator & values
    • Repairs
    • Stopcocks
    • Waste disposals
above prices are far too cheap, will never become billionare at those rates
you would never have any work in this area if you charged those rates. god wished i could lol
Thanks for all the useful feedback. Trust me I'm not at all cocky. I know this post appears that way but I also know this is the place you can throw these questions out and get some sensible answers. No I'm definately not cocky....a bit ambitious maybe but its either that or carry on working a rubbish job forever and earn not much and never take an ounce of pride in my work. Thanks again guys
Just cuz you work for someone else, does not mean you cant take pride in your work!!! The people you work for with your employer may be one of your own customers one day! Thats not likely tho if you dont take pride in your work.
So you're going to hoover up all the work we can't be bothered to chase and set the plumbing world alight but only after we've told you how much we charge? That's a classic lolGood luck.
Ha ha not at all matey. I'm just trying to build a picture for myself. I'm not trying to ask how much you earn, just how to break down the process of how to charge customers without being too greedy or too generous. and as for my rant, I've just had enough of people trying to put me down before I've even started a career. The worlds always going to be a tough place, I don't need pesimists to tell me that. I'm not going to lose sight of my goals but I'm not naïve either.
Your dead right mate. I'm a supervisor in retail at the minute and its killing me slowly, but it is a job and for the time being its just about paying the bills but its not what I want to do. And as for the potential customers, I've already got a few lined up from my current work. I give a very good level of customer service and it does pay off. I'd just rather be giving that level of customer service as a plumber
When you get into Plumbing you will just be paying the bills too, Building trade is at rock bottom, if you have got a steddy job, with long term employment, pension ect you would be better off sticking to it, forget working for your self, within the next 10 years the small Co will be squeezed out ,with costs and paperwork, the days of the sole trader are numberd, Glad ill be out of it soon !! But best of luck youll need it,
Thanks, I know I may need the luck to get off the ground. My job is not very secure at all mate, find me a job that is
Hi, i know of a plumber who was asked by a independant builder for a price to fit the loo in a house, he quoted £120, he gave it to another guy who charged him £50. The £50 made a few quid and the builder is happy and the plumber is now his regular "go-to" bloke for fast turnaround work. Price your jobs appropriate to your customer
Geez... make my day mate eh?
Reply to the thread, titled "charging for jobs" which is posted in General Plumbing Jobs Discussion on Plumbers Forums.
Kyle87,
Kyle87,
