Cheapest Combinaton boiler
View the thread, titled "Cheapest Combinaton boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Martin that is fine mate, but advertising his services at this rate is not doing good to any body !!! this is why we have plumbers arms for !!!
i agree,,
any price comparison take it over to the plumbers arms. if you cant get in then contact dan or dave for the key.
otherwise custards in london may think they can get a combi fitted for£99.99, with a very small but valid chance could affect the market. who knows its bad enough allready.
i agree,,
no problem
Went to the ldeal logic training course in hull yesterday. was surprised how good it was. got to strip down etc very easy to work on 5 year warranty that has to be a good selling point..
5 years warrantly is all well good, but if they dont service it every year then it is void, as many custards are worried about price, getting things done as cheap as possible, do you think they will get it serviced for every year.
That's up to them, if they don,t get it serviced then why would the man,s cover it ?
If you buy a new car it has to be serviced to be covered for warranty.
Monza 24kw Band A Boiler £415+VAT at tradepoint
Heatline’s Monza high efficiency condensing combi boiler has a 28kW hot water output and a flow rate of 11.4 l/min with a composite stainless steel heat exchanger and modulating circulation pump. It’s compact, lightweight and highly efficient with a factory fitted analogue time switch, flexible flue options, in-built frost protection and comes with a 1-year warranty as standard.
Only £499.00
What is theCheapest Combinaton boiler on the market?
I try to tell customers that a a good boiler well fitted that incorperates a magnetic filter system and a good inhibitor installed will last far longer than a cheap boiler that is chucked in.
Some listen some don't.
So I'm thinking of when pricing giving a an itemised estimate.
Good boiler
Rubbish boiler
Power flush or no power flush
Manetic filter or not
Scale reducer or leave it out
Inhibitor.
At lest then they can see why I'm a million £ more than the next fella
[URL="http://www.cityplumbing.co.uk/searchHierarchy?hierarchyName=Ferroli&productDisplayType=PRICELISTCATALOGUE&lowestLevel=true&hierarchyType=VALUE&category=354&attribute=1&displayType=BOTH"]Ferroli are one of the cheapest A rated boilers around with 5 years warranty
[/URL]
Only £499.00
fine if a custard wants cheap,but when you weigh in a detection electrodes nearly 50 quid its more economical to fit a middle road like a gold
i don,t think they are too bad if they last the 5 years, means we get more work ,as long as we advise the customer that ferrolis are not one of the best boilers.
Reply to the thread, titled "Cheapest Combinaton boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
Bodd,
Heating-eng,
