Check valves on mixer taps
View the thread, titled "Check valves on mixer taps" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello,
Do I need to put a check valve on the cold feed of a bathroom basin mixer tap if it's on a Combo boiler and the tap is dual flow as opposed to a single flow where the water is mixed in the body which I understand should have a cv?
Cheers
Thanks Shaun,
I didn’t see this reply.
Looking at the other scenario. Is there a need to put a CV on the cold feed if it’s a combi and the water is mixed in the spout or does the combi wipe out the complete need for a CV.
In theory anytime water mixes yes but in reality and domestically this never happens
(Best practice )
(Best practice )
Thanks Shaun,
That makes sense as when I asked a few seasoned plumbers about dual flow and mixing in the body they looked at me as if I was an alien. Especially when I mentioned using a CV’s.
I assume the possibility of water mixing is quite rare even if you have a tank.
Also l don’t think I’ve actually seen many cv’s in my travels if at all. 😊
Thanks Shaun,
Yes more an issue on unbalanced supplies
Reply to the thread, titled "Check valves on mixer taps" which is posted in UK Plumbers Forums on Plumbers Forums.
Tezzer2022,
ShaunCorbs,
