most are 11k ohms at room temp
A lot may be around the 11k ohms mark at room temp. A lot are not! What is your room temp?
For example (based on the manufacturer figures I have to hand from recent checks):
Worc. 24CDi, 280RSF, CDi(older) are all around 25K ohms at 25°C
Greenstar 15k ohms @ 20°C
Alpha 240/280 is 14k ohms @ 25°C
Pott. Performa, Promax HE 10k ohms @ 25°C
Most vokeras are around the 11k ohms @ 20°C
As I mentioned the MI's/Manufacturer should be consulted for accurate figures.
I think you may be a bit out with your figures GrahamM. You're more likely to get 1000ohms hot rising upwards the colder the water 🙂
Oops, I missed out the 'k' in front of my 'ohms'.
And just to clarify, the resistance decreases (number increases) on an NTC resistor with a rise in temperature.
