Guest viewing is limited
Ferroli Modena A01 fault code
View the thread, titled "Ferroli Modena A01 fault code" which is posted in UK Plumbers Forums on UK Plumbers Forums.
armyash
Subscribed
Hi, I have been asked to look at a Ferroli Modena tomorrow evening. I've been text the details by a letting agent. They have requested I attend after 7pm, fine by me I have a job around the corner at 6pm.
It's giving the fault code A01. It's an ignition fault. Is anyone familiar with this?
I will be doing the usual checks, flue, gas on, condense pipe etc. Will check the pcb/fuses also.
Looks as though the gas valve is a possibility too. Are there any readings I can test for on the gas valve? I won't be able to call the manufacturer while on the job.
Reply to the thread, titled "Ferroli Modena A01 fault code" which is posted in UK Plumbers Forums on Plumbers Forums.
armyash,
