Cold Radiators
View the thread, titled "Cold Radiators" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Yes as a TRV may still pass when screwed right down. Without having a 2nd beady eye on what this guy has done you may never know as he could just keep trying to pull the wool over your eyes 🙁
Me thinks it's not that daft, there are 5 rads not getting hot, that means he's done it five times, he would then be the real plumber from hell, too much speculation going on an not enough facts, I will sort it out next week chaps and I will report back, it will not be just one thing wrong. leave this one alone now and I will be back.
Tony
Sorry just getting in on this coz I love a mystery
What do you think it might be Riley???? we could have a met,:21: throw a party :cake: play cluedo :beatnik: or simply have a cuppa:coffee: I will let you know don't worry.
Tony
Make sure there is not a uncontrolled by pass
SafeGasInstaller,
I have a bit of kit that sits on the pipe and measure the flow inside, I will spot the uncontrolled or controlled bypass in a flash, I don't want to worry about me either, I have been in the trade for the 55 years and as long as the Good Lord doesn't take me in my sleep before I go to site next week, I will sort the plumber from hell out, be assured, trust me I am a real plumber!!!:35:
BTW I have heard they are going to officially make plumbing a trade next week :lol:
Anyway do any of you know when plastic tube was first used for minibore central heating???
SafeGasInstaller,
Jesus this is like a plumbers version of Eastenders... Loving it
Have you been back yet Happyflyer? If not when?
Just to chuck my 2 pennies piece. When that plumber left did he jump in a van or ride off into the sunset!!!!
Tommy
Me as done, put the old trusty test kit on and found the water flow was too low, lots of other things need to be put right boiler in the roof space, with two zone valves pipe to valves go up higher than boiler so boiler is not the highest part of the system so auto air vent in boiler not much use, got plumber back, programmed boiler to run pump at full speed, twas only running at half, closed down ABV and got water flow up to boiler recommended rate, all rads now (WOW) get hot except on on new index circuit, balancing now tight, main F/R in roof space rises up to where it drops down to Ist floor needs 2 AAV and pipe cutting shorter, needs two AAV on boiler end zone valve branches, you need to remember that the Valliant like others don't have a big pump on 20 Kpa this is not very much for long runs of 15 mm tube, If I was fitting a boiler which feeds heating and a Magaflow I would use a basic boiler without pump, you can then change the pump if you drop a clanger.
Tony
PS the plumber who did the job now calls me Dad and I will take him under my wing from now on, why because he listened, the day you stop learning is the day you die and that includes me.
Rock on Tommy
Fair play to him for not getting his back up.
I'm impressed too.
Whats the test kit? Sounds like a nice toy to play with.
I've never thought about fitting a boiler with out a pump. Every day is a school day and I've just learnt something.
Rock on Tommy £2500.00 Portaflow a bit more now had it 4 years
I'm impressed too.
Tommy,
I didn't go well for about 15 mins he thought he new it all, after he saw the kit I had he saw the folly of his ways, seriously he
was a nice young chap would I would help any time, he took my card and said if I need any help can I call you, what do you think I said.
Help some when you can I might need it one day.
I spend all my time now witnessing other people commissioning water and ventilation systems, I write software for Building Management system BMS, controlling commercial HVAC, I use to be in combustion also for 10 year, Hamworthy, British Gas and Oil Burners,(BGOB) or Selectos as it was know, I have worked on burners with 15 ft flames, mainly potato crisp machine they need lots of power to heat up the fat. I worked on the very first premixed gas burner, you use them every day in domestic boiler, I was part of that design when I was 30 I am nearly 70
Hi again
Tony has been wonderful!! We can't thank him enough...
When I arrived home from work this evening.......All the radiators were hot!!! A miracle!
Tony....It's too hot now! ha ha ha...
:waving::teeth_smile::teeth_smile::teeth_smile::teeth_smile::teeth_smile::teeth_smile:
It's very clever indeed...I learned a lot yesterday...I'm thinking of becoming Tony's apprentice!
Tony is an inspiration!
Just a thought how are the rads pipe BBOE or TBOE. If they are TBOE then they could be piped back to front. causing only the top to heat.
julesG,
No one these days pipes a radiators TBOE, do you know why, well it would be 750 mm of 15 mm tube for each rad and that would need do, anyway for what reason would any one want pipe TBOE, that is remnants of the old one pipe system, long forgotten here
Thanks Jules,
Just another day at the office, I can't imaging helping anyone better, hope you have happier times ahead now the heating sorted.
Tony
Happy flyer,
I'm was just making suggestions. I'm sorry but I disagree, TBOE is still the most efficient way to pipe a radiator regardless of whether it's a one pipe system or not. As it gives a better spread of heat across the radiator. Perhaps not seen in most modern homes but in industrial and commercial buildings are still occasionally piped this way. I piped radiators in college that way and I've worked in modern buildings piped that way. If you can increase heat output with piping arrangement, perhaps you can reduce heat emitter size?
Except by the guys who wrote BS EN442 for measuring the output of rads, who specify TBSE when measuring! There's only about 2% difference between the three connection methods and TBSE is the best.
Isnt it tboe? Tbse causes the heat to run down one side and not circulate within the rad.
tboe causes it to run across
I agree with you 1King55, I was always told that TBOE had the highest efficiency, I would say that TBSE would have the least of the three.
You chaps are right experiments show that there is approx 2% better output if you don't use BBOE, but pray tell who does have a pipe running up the side of a radiator to the valve, another point if you do this and add a thermostatic valve the heat convected up from the stand pipe will prematurely shut down the valve, see if you can find a glossy rad brochure with TBOE connections.
Tony
Incorrect happy flyer, you fit the thermostatic radiator valve horizontally for exactly that reason. The phial in the valve hangs clear of the pipe and so isn't tricked by the heat from the pipe. If you were to fit the valve vertically you would be correct (which is a common mistake). As to whole has a pipe up the side of their radiator, the answer to that would be people looking to get max efficiency out of their radiators.
They are talking commercial, and you are right and forgot to add if you fit the TRV with the head horizontally you will negate the convention current up the pipe, another alternative is to use a remote capillary, but all this costly and messy, and they can get damage easily, commercially we tend to have a single zone valve controlled by a BMS and a room sensor, usually with a 3 Deg C adjust band 1.5 up and 1.5 down from agreed set points.
Owning and operating commercial HVAC system is expensive and maintenance must be taken into consideration too, in a school there is now a tenancy not to install radiators with TRV, they get damaged and messed with, UFH is pride of place no one can fiddle and even quality bespoke dwellings do use radiators.
I have designed 6 bespoke house in the past 10 years and not one radiator anywhere, the spec building will take some time to catch up but I think they will.
We have in recent years seen power sockets lift up higher, you could put the rad valve TBOE so people don't need to bend down, I have electronic rad valves on my system, don't need to bend down, once they are set you never need to adjust them again, extremely accurate temp control, they even make wireless TRV and the World moves on, as for 2% extra output using TBOE we will need the tweak the ABV or use the next size boiler up one. :bigcry:
Tony
Ive done the rads in my parents house tboe. For one its more efficiant and also easier to get the rad off.
Look. its whatever floats your boat if you fit TBOE when you come to take the rad off, there is a lot better change of air going in and water coming out and all that black crap on the carpet, if I even get my tools out the shed, I will still use BBOE.
Here's an idea try piping up TBOE with 15mm plastic, will it stay straight I wonder and the grand kids can swing on it, or mother bang the hoover into it, never catch on up North, hell lets go back to steel, sort the men from the boys.
At least it will make you use copper for the last bits.
Tony
Absolutely not! The rads are still working wonderfully well Tony.. A brilliant job! They booted up this evening and were all hot in less than 10 minutes. I've now decided to turn down the control!
:yes:
Would be ok if you painted the top pipe pink as well, it would be invisible 😉
Is that the rad in VT's room?
Happy flyer,
I didn't forget to add anything. TBOE is still regarded as method of piping and is still relevant today. That was the original point, regardless of convection currents or methods of installing TRV's. TBOE still has it's place in todays world, TBOE systems are still being installed. We can debate the point all evening, but it won't change that. I agree no one in their right might would pipe a tall radiator pipe in plastic. I also agree TBOE is not often used in the home, but not often isn't never. You can't blanket disregard a pipe method based your points. As for schools, would you not need low surface temp covers anyway? Many of which encompass the pipe work and TRV and are anti tamper. I see no reason why this piping method couldn't be used in a school with the use of a low surface temp cover.
Reply to the thread, titled "Cold Radiators" which is posted in UK Plumbers Forums on Plumbers Forums.
lucolivia,
Killy Bing,
