Combi boiler flue location over my boundary
View the thread, titled "Combi boiler flue location over my boundary" which is posted in Gas Engineers Forum on UK Plumbers Forums.
My question is simple;
Does anyone have factual knowledge of the 600mm minimum distance.
Is this a regulation or a recommendation?
Background.
Neighbourd new boiler installed with Flue over my boundary. I approached the new owner his response was 'do your f*ckn worst'.
So I'm on it. Below is 'gas safe' reply and waiting for building control to report back.
If building control washes their hands of it and tries to put it down the legal route of boundaries it says. Lad's bang flue where you want as long as it's safe.
Gas safety response
I can confirm that Gas Safe Register had written to xxxxxxx on xxxxx indicating that a concern has been raised with the property flue, and offering to undertake an inspection. Your details have not been divulged in our correspondence. To date we have received no response from xxxxxx authorising us to attend.
As per our Consumer Policy (attached for reference) Gas Safe Register has no right of entry concerning gas work carried out in your neighbours’ property, unless we are requested to investigate concerns raised directly by the property owner. As we have received no such contact we are unable to take further action.
We would suggest that you raise this issue with both your local Building Control and Environmental Health office. Where there is an immediate concern for gas safety, for example if you suspect that you are being exposed to products of combustion from the neighbouring flue, we urge you to contact the National Gas Emergency Services Provider on 0800 111 999.
If you wish to reply to my email, please reply to [email protected] this will mean you will receive an acknowledgement that we have received your email, and it will still be answered in my absence. Please also note, when you email us, we aim to reply within 5 working days. If you haven’t heard from us within that time, please do check your spam or junk folders.
Just block the flue terminal or air intake terminal with tape or something.
This will block the fan pressure switch inside the boiler and not allow it to fire up.
When the neighbours want to access you property to check the flue, deny them access.
On second thoughts, just block the air intake section of the flue, if the boiler fires up at least you will enable the products of combustion to escape from their property and not end up on a manslaughter charge.
You could always spray a hose into the flue and say it was your sprinkler system.
Building Regulation. Part J Diagram 34 (assuming its a gas boiler)
Boundary as defined in paragraph 0.4 (4) op cit.
Note that "Smaller separations to the boundary may be acceptable for appliances that have been shown to operate safely with such separations from surfaces adjacent to or opposite the flue outlet."
So "We would suggest that you raise this issue with both your local Building Control and Environmental Health office." is the correct way to go.
It’s a regulation
But can I ask is it that much of an issue playing devils advocate?
Causing problems / damage ?
Many thanks for all your responses
Oz-plumber
At present I'll let it run it's course through 'regulations'. I'm well within my rights to park a wagon at the side of it etc. Knowingly creating a safety issue is not on my remit.
Chuck
Thats the direction I'm at, building control I've not looked at hse as yet, time will tell whether I need to take that step. This potentially make a good case study.
ShaunCobs
I half expected that question and rightly so. There's an old saying principles cost money.
But, there's more factors than this, to which I didn't want to dilute the question.
As in 'devil's advocate I'll put it back on your toes and ask; what is the point of having regulations?
Or is it, let's just do what we want, when we want, how we want?
I'm not disagreeing that some are a pain, EPC is a prime example.
We all let a lot of things go for an easy life.
Oz-plumber
Chuck
ShaunCobs
To protect people / life to simply put, any pictures of said flue ?
Next thing it will be on the 'Dull Men's Club'. Boiler flues. Please take that as a laugh.
Reply to the thread, titled "Combi boiler flue location over my boundary" which is posted in Gas Engineers Forum on Plumbers Forums.
2260quid,
2260quid,
