combi boiler plumbed as a system boiler advice please
View the thread, titled "combi boiler plumbed as a system boiler advice please" which is posted in Boiler Advice Forum on UK Plumbers Forums.
F
fraz63
I,ve just had a gas safety inspection done and the engineer pointed out that while the boiler was a combi type it has been plumbed to heat a water tank, what he called a system boiler, should I have the boiler re-plumbed to operate as a combi.???:thinking:
Not that unusual. I installed a combi at home as a quick fix during the building work we carried out here. Now it functions as a system boiler with just the kitchen hot tap being fed from the combi element.
combis are cheaper than system equivalents to buy, so a no brainer really
I've fitted many combi's as system boilers over the years, always works a treat.
And as already mentioned, still the combi option for a nearby draw off or two.
why not done them in larger houses - had combi hw side feeding kitchen taps for instant hw and then fit an s plan to feed htg and unvented cyl nothing wrong with that .also seen combis used as water heaters only where the htg is just a 22mm pipe looped under floor and back
Is the combi set up cheaper to run? I mean, and forgive any plumbing ignorance, but as I understand it the boiler will be keeping a large tank in the attic heated to a constant temp ready for use,( all hot water taps are supplied by this tank ) whereas the combi set up only heats what you use.yes??,no?? ergo, not burning gas when not in use.
Makes no sense to me I'm afraid.
why pay more for a system boiler when you can set up a combi as a system boiler on a cyl for less as combis sell more they are cheaper than a system boiler in the first place.hence no brainer for those with a brain:rolleyes2:
You may have a system boiler with a diverter kit that fits to the boiler. I some times use this set up depending on existing pipe layout and condition of existing cylinder.
Or as said in previous posts could be a combi feeding some out let's and cylinder feeding others which in some cases is a good set up.
A way to tell which system you have is run hot tap nearest to your boiler and if boiler fires up then goes off when you turn hot tap off odds are its a combi.
You will have to have your heating and cylinder time switch off if you try this.or post some pictures.
a combi will only give you a limited supply flow rate of hot water. This is why they are sized on hot water output.
Well if you would have put that in the first place we might have had an idea what you were wittering on about.
I moved a combi to a new position and the customer wanted an unvented cylinder fitted. The boiler was sitting around for a while till it could be fitted.By the time i got new flue, condense trap, front panel etc because things were lost and damaged it would of been cheaper to by a new system boiler. Some customers think they will save money.
we often used a combi as a system boiler as they are often cheaper as the price wars ttend to focus on combis we would put the kitchen on the combi hot water side so always hot water there
I have no problem with the combi being used in this way, its just that with the set up I,ve got, I have to wait till the tank/cylinder in the loft has warmed up before I get any hot water, I was trying to get an Idea of how a combi hot water supply compares with a system supply, its a two room, kitchen and bathroom, tenement property and I havent got into the loft yet to see how well the tank/cylinder is insulated, Is it possible to have the system checked for performance.
If you have no instant hot water and have to wait for your cylinder to warm up. then it looks like you have a system boiler which is not a combi boiler.
Or it could be that you have a combi with no instant water draw off. Neither case is anything to worry about unless later on you have a persistent demand for short term hot water when a combi would help. This might require a small amount of re-plumbing if your boiler is a combi.
What if the boiler is in the loft and you cant hook the DHW up to the kitchen (sensible option)
Does anyone just leave the DHW isolated under the boiler and let it just heat the cylinder?
No problem using a combi as a system boiler providing the DHW side of the combi is a water to water plate heat exchanger not a gas to water heat exchanger on a few dual heat exchanger models.
what about the intergas one thats gas water and can be used as htg only
I'd be very surprised if you can't with an intergas as you can run them with the CH side empty.
i have never heard of this but what a great idea, do you need to do anything other than an s plan, ie wiring....to the" combi" or do you fit as per combi with the addition of s plan.. what about the diverter valve if the heating is calling and the hot water on the s plan side then someone opens a local tap off the combi side ?????
Mark
Dual heat exchanger. will need water in the DHW side otherwise it could melt down. Best ask Intergas themselves. Will stand corrected if they say you can.
I was at trade show 2 years ago and the inter gas stand told me that you cold fill just the domestic side to give the customer domestic hot water while you poss upgrade the heating next day as a bit of a selling point.so i suppose if this was the case you could fill and run just heating side. but was only a verbal chat. if any one was to wont to do this I would have it confirmed.never installed intergas so never needed to follow this up.
You were right about this Intergas boiler. They stipulate in there instruction manual, that you can use it solely for HTG or DHW. Just have to change the parameters on corrospondingly.
Reply to the thread, titled "combi boiler plumbed as a system boiler advice please" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
fraz63,
Reg Man,
