combi with stainless steel heat exchanger
View the thread, titled "combi with stainless steel heat exchanger" which is posted in UK Plumbers Forums on UK Plumbers Forums.
have decided a stainless steel exchanger is what i want in boiler, as it seems to be when you buy breakdown cover some places exclude heat exchanger
i know baxi platinum is , awaiting installer list from ATAG but unsure they will be too new for back up support in my area,
so whats best i had originally looked at gloworm as they made by valliant but the exchanger is aluminum so i think i have crossed that off list.
is it right that you dont use inhibitor is stainless steel is that a benefit??
You use inhibitor irrespective of what type of hex you have, don't forget the rest of the system needs protection from corrosion too.
Veissmann use SS hex.
Could I suggest that you don’t buy breakdown cover as your boiler will have xx number of years warranty and just find a recommended local gas safe engineer to service in line with manufacturers requirements. I would still recommend Vaillant/Glowworm and you can get up to I believe a 15 year warranty on both if serviced by their people.
Some breakdown companies won’t cover if boiler over 7 years. Not trying to be awkward but often they’re a lot more trouble than they’re worth and they always try and wriggle out of their responsibility
well found the glow worm energy which can offer up to 15yrs but heat exchanger is aluminum, they dont do stainless
so is it a myth that stainless better, yet vaillant do SS HE but they cant honour that length of warranty
WHY is there 2 threads on what is basically the same Q?
Reckon the op has enough Intel now to decide but can see it continuing over the weekend.
Never ever ever had a problem with Glowworm warranty on the couple of times I’ve had to call them out.
Vaillant do a 10 year warranty is you find a Vaillant accredited installer.
Reply to the thread, titled "combi with stainless steel heat exchanger" which is posted in UK Plumbers Forums on Plumbers Forums.
craftyset,
Alpha man,
