Aslong as it's a u16 or under yes they can
"A maximum installation volume supplying an individual dwelling or non domestic premises of 0.035 m3"
I posted that ?
Not when gas safe are involved a domestic engineer can work on / change a commercial supply aslong as it's under 35mm and valved so it's under 0.035 what there working on
You posted that!
It's simple to me and it goes like this:-
1 Is the 'Primary' meter U16 or smaller?
2 Is the installation pipework 35mm or less?
3 Is the Maximum installation Volume including the primary Meter less than 35 dm (0.035M)?
A 'yes' to those three will confirm that a domestic engineer can work on it and therefore whether it is a Commercial or Domestic sized Gas installation (pretty much and even though I think it barmy but that is another subject).
So in answer to your comment Shaun First off we need to decide whether the installation is classed as Domestic or Commercial.
If it is classed as Commercial, then a domestic engineer cannot work on it. Even if they section a part off that is smaller than 0.035m. This is because the installation is commercial and at no point does it change into a domestic.
