Commercial plumber req
View the thread, titled "Commercial plumber req" which is posted in Industrial Plumbing Advice Forum on UK Plumbers Forums.
I am looking at instructing a commercial gas safe registered and plumber to start works in moving an existing plant room and also expand it.
Requirements:
Moving two ACV direct hot water tanks , adding one more
Installing 6 accumulators - piping a header
Tank
Preparing and install riser for
Clod water, hot water, flow and return
Main pipe work to be in copper or mlcp to be considered
Pipe work to be 54mm
If possible also prep for UFH Manifolds or can be done by others
I am looking to start the works as soon as possible.
Please let me know if you are interested in the works.
Darren
Location ?
Hi Shaun,
Hotel is in Camden, parking is available on site. Contractors that are out of London can be provided with digs.
property is currently closed and system is disconnected.
few more details-
New steel gas pipe to come off existing u16
Corridors are over three floors where each room will branch off landing
Any experience in Uponor larger commercial fittings is advantageous.
High flow rate design requires attention to detail
What is the start date for the works? Has a design already been done for the system?
Reply to the thread, titled "Commercial plumber req" which is posted in Industrial Plumbing Advice Forum on Plumbers Forums.
Hotelcontractor,
mfgs,
