Communal Rising main water pipe
View the thread, titled "Communal Rising main water pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all.
Doing a house renovation here at my flat that I owed for about 20 years have decided finally that time to spend some money on myself and live normally.
Basically knocked out larder cupboards and walls making a kitchen diner finally got permission from the freeholders that took about 1 year alone.
Behind one of the Larder cupboards there is as follows 4 pipes on the wall going up and down
These are down services from the the roof of the block of flats a water tank used to be attached next to where this main is.
There is one pipe this is what the problem is about 60 cm away from those pipes in other words in the actual kitchen its 28m copper and above it there is a join to about 35m copper.
At first we believed this was the down service but after realising it appears to be the water that is pumping up through all the flats into their water tanks and then into the main water tank on the roof. SoI have a water pipe in my property that does not serve me there is no stopcock at all within my property yet I am told I am responsible for it.
We want to re-route this pipe back to the wall.
Contacted Thames Water and they seemed quite confused about this pipe but did indeed find it on thier system.
What would be the best way to tackle this they told me that you could possibly try to turn this feed off from the ground but surely it's getting pumped up due to gravity? So would you not need to turn the pump off as well where would that be? Other option would be to freeze or to use an Aladdin clamp and basically to re-route the pipe back to the wall is there any issue removing this pipe I'm presuming the water will still be able to travel up the bends being about 60 cm back to the wall all and then out again 60 cm in?
Obviously for the duration of time there'll be no water being pumped up to the main storage tank I presume this will not affect the properties with the water tank in the house because the main tank upstairs has about 10000 l. And we only need 1h.
Happy to take pictures but meanwhile just wanted to pick everyone's brains and I was wondering if anyone has experienced this sort of job and are there any worries at all?
I'm pretty worried about cutting the pipe using an aladin clamp and freezing it because if something goes wrong there is no stopcock within my property to turn it off and water damage could be totally catastrophic
In fairness, I'd be confused if I were the OP. KOP has given good advice (which won't take anywhere near a year), but what actually differentiates a firm that specialises in these from a firm that doesn't, and how does the OP know if the firm is any good? What trade membership/approval scheme or qualifications should the OP be looking for? What questions should he ask the prospective contractor?
If the OP chooses a reliable and trusted firm with a reputation to lose and that is insured for this kind of work, although the OP may be liable, it would seem likely that any counterclaim against the firm would be settled should there be an issue. It is an interesting question though - if a plumber working on a customer's house and burns down the street, who do the neighbours sue - the customer or the plumber?
The water undertaker may not be interested in a formal site visit - they may just send some guy under subcontract to label the isolator and that would be it. The building services manager may not be very au fait with this either otherwise the best course would probably be for the building manager to instruct the work and charge the OP.
I think the surveyor is a good start, so what does the OP need to look for in a surveyor? RICS? I'm just a bit unclear on how the OP would go from #28 into practical action.
It actually could take a while as you need to get approval from the other properties to turn the main off to the whole place for a day then you have to provide temporary toilets etc
True, I suppose it depends how many other properties are involved and how helpful/obstructive the neighbours are feeling.
So it isnt a mains water supply at all and you only need to give 24h notice .
When you turn it off it wont affect anyones water as this water goes up into the tank then there is a down service. So theyll have water.
The work only takes about 1h max specially if you pre cut and make ready.
I spoke to my builder to go and email his insurance company and tell them exactly what he's going to so turning a valve outside the property and then modifying the ***unal pipe
And getting it in writing that he is covered.
Then I'll do one of two things just go ahead as he is insured and has it in writing or email the freeholders asking for for advice on the situation.and confirmation what were about to do. Meanwhile I'll probably end up losing my builder if I keep delaying this..
Regarding commercial plumbers I've spoken to a lot nobody really wants to take the job on and even called up Pimlico Plumbers and they said they don't take anything communal..
I feel stuck some what I'm hoping to come across someone that has dealt with this exact scenario in the past I can't be the only person.
I would love to hear someone say don't worry about it I've done this before something like that but looks like no one has so far.
Does anyone know how this down service water tank system works exactly Thames Water seemed a little bit shocked that I have a pipe in my house that doesn't serve me without a a stopcock.
Like I say it looks like I have found the valve directly outside 3 Floors down in line with this pipe about a metre in the pavement.
My first point of call going to be my builder make sure he's specifically insured for this.
I take every piece of advice you have given here ultimately I need to make the decision.
I would love someone who has experience doing this has the right insurance take this on
Your contradicting your self the tank will be fed with mains water
Also the work will take longer than an hour as your going to have to solder it no pushfit
Also your builder isn’t capable of doing this work
I stopped posting but kept viewing as I guessed how this thread would run.
However, given the information since I last posted I would say the position is as below;
Each flat has it's own dedicated mains supply to the kitchen sink from the stop taps found outside and this is the supply being used for everything in the flat that's the subject of this thread.
Additionally there will be an extra stop tap for a feed direct to the Landlord / Freeholders tank in / on the roof.
From that tank there will be several drops to the flats below, reducing in size as they go.
These will have been cold feed to the cylinder, cold for the bathroom taps and W.C
The cut off bent over pipe will be the vent from the old cylinder and it would then seem most likely that the other adjacent pipes are vents from cylinders in the flats below.
Final post.
Final post.
I sent you a private message but looks like you're onto something however the only thing you didn't explain was the big pipe that's in the way that is not connected to the kitchen main.
Am I right to think it's a seperate main going up to the tank. Remember when I turned off the the gate valves they had no water in their bathroom but this dead legs on the left continued to continued to flush water .
I'm also speaking to a local plumber but I want to be overly sure as nobody really knows exactly what this is my builder as well of course you're right it's not really a job for him..
I appreciate it was your last post but as you can see it's not totally resolved yet so you kind of said the man's coming in from the kitchen only but this pipe why is it live.
The other pipe was the kink obviously isn't in the way so that can just stay like that.
Are these still need advice.
If you prefer not to post I would be grateful if you contact me privately
If you can pinpoint this and solve the mystery I'm happy to send you over some money I'm serious
I would expect one of those gate valves on the big cold water storage tank on the roof would isolate the pipe you need to reroute? I would guess that pipe was a cold feed to the removed hot water cylinder maybe something like a Elson type cylinder? Google it ? , as your neighbours still have these installed that's why there's still water being used through that pipe, the way to check is trace the pipe back to the tank if possible ? you know which gate valve isolates the bathroom cold supply so it's not that one ok ! if there's another gate valve close to that turn that off ? you will need to run a hot tap for a good few minutes in a neighbours property or rig a hose up connected to the branch hanging down via the stop tap in your property into a drain you may well find you eventually gain control, it's not unusual to find these gate valves partially pass water even when fully closed sometimes this is manageable with proper planning , having the replacement pipe pre made and fitted as much as possible allowing the last couple of joints to be done really helps, I would honestly advise using a crimp machine and the appropriate fittings avoiding any hot work and if there's a little water then it's not a issue as long as it's manageable . Regards Kop
Hi I close all the gate valves and I ran that little branch on the left for half an hour.
I traced that particular pipe up and found the particular stopcock but I also turned off the gate valve where that lead to if that makes sense.
Is it not plausible that they're getting the main water from the pipe I'm trying to re-route?
Its not impossible I suppose ? but it's wouldn't be as it was installed and there would be a alteration done to redirect the mains water into the down service pipework usually at the tank if its untouched then its less likely I would say , you need control of that water if its tank or mains? ideally the mains, get the plumber involved to get on to Thames water sometimes you need to not take no for a answer . Kop
Hopefully this picture helps
. It's a horrible Pipe that's 60y old it looks rusted and it's my responsibility is dangerous as you can see it's sticking out about 60 cm into the kitchen totally in the way it needs to be rerouted.
I've got permission to do the Works.
Hopefully my previous post made sense when I was in the loft we turned off the stop cocks that was the Down service . We tested all above and below and they didnt have water meanwhile on the left area of this pipe we have water flushing out for half an hour now it doesn't Close anymore so we had to get a special fitting.
The fact the water never stopped made me call another plumber by the way I had three plumber's out here all of them gas registered.
Two out of the three said it's down service they were wrong one of them said is an old gas pipe.
Then I got another one and he told me this is the water going up into the tank in the loft which makes total sense I don't have a tank system anymore it was taken out before I got here.
You are legally allowed to turn water off as long as we notify the people 24 h notice.
The last guy who came seems to know his stuff he said he's done quite a few of these but obviously I want to check because this type is causing us a lot of problems.
Hoping to hear some positive news what's your thoughts now that you seen the picture
Good evening everybody.
I'm hoping some of you very good people out there will remember this post of mine.
Here is what the situation is.
Decided not to freeze as it was too risky we had to repair the valve on the roof which was directly underneath this pipe.
It took the freeholder about 1 year to fix it absolutely Madness but don't ask.
They've eventually replaced it.
If you remember I was a little bit confused what this actually was because I have turned some Gate valves on the storage tank and for 25 minutes the water did not stop.
Well we now know exactly what this is "it is the town service which feed the hot water cylinders"
I have highlighted this post as it contains the photograph for quick review.
Have you can see my property does not have the water tank. Hence why this needs to be rerouted.
Well I'm leaving it a bit late but tomorrow is the faithful day.
The section of the joint appears to be 35 ml imperial I think we're going to go and work off that. We have a soldering joint 35 ml reducing to 28 ml. We also have the compression 35ml going to 28 mil.
The section at the concrete and the section at the bottom below the concrete would it be ok to use soldering joints or do these need to be compression? Yes I am using a plumber fully insured he has initially said soldering joint all the way?
I have taken notes to thoroughly clean the sections as somebody has also advised that it can damage the risers beneath me they have also said to be careful it does not crack in the concrete that's going to be quite a nightmare.
I suppose I'm a little bit nervous even though he has insurance. And I would just like to know the best methods to reroute.
And any other tips along the way that I can tell the plumber tomorrow morning.
He says he has plenty of commercial experience and he's done this many times before but obviously another question I want to have is what happens if something goes wrong and a crack does appear in the middle of the concrete.
That will be quite difficult to rectify won't it?
I know I'm worrying before nothing happened but sometimes it's good to have that mindset so you can be prepared for it.
It will be wonderful to hear from you all again thank you very much
Hello everyone unfortunately this is not been resolved yet.
Long story short the valve was not repaired on that day it took another 6 months and I lost the plumber who was interested many plumbers are not interested in doing the job so I found another one
He came he turned the valve and then eventually hot water started coming out he stopped it and said he has to investigate further and that it could be some sort of a back feed and he's not sure and now he's also disappeared.
This is very frustrating God only knows what I would do if there was a seriously on this pipe there is no control in my property.
Pimlico Plumbers do not do communal many other companies have disappeared after I asked them for insurance because it's a requirement from the freeholder.
I've posted the job in the job section as well but I really just want some further advice and if anyone is at all able to take this on anywhere in the country please let me know and I will pay travel costs along with your time rate
We are really looking for help here
Reply to the thread, titled "Communal Rising main water pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
Pipeman222,
Lou,
