Condensate Drain
View the thread, titled "Condensate Drain" which is posted in UK Plumbers Forums on UK Plumbers Forums.
W
witheveryone
What products do plumbers generally use when terminating the condense drain from a condensing boiler?
Strap on boss to soil stack or rainwater downpipe / Waste connection to 40 or 32mm / straight or P traps?
Does anyone ever use an air break or check valves?
Any info would be appreciated! 😉
Thought condesate must terminate over a grated draincover...no air gap required in it's length...(if it is'nt connecting to a waste pipe which i'm sure is perfectly ok.)
Reply to the thread, titled "Condensate Drain" which is posted in UK Plumbers Forums on Plumbers Forums.
witheveryone,
fizzput,
