Just my opinion not to comment on it anymore mate that’s all. You can comment all you want. But I have the GSR badge and it is my A**e on the line when someone doing illegal works points to this website after installing there own boiler with a soakaway. @ShaunCorbs may say it’s fine but still only my opinion.
That`s fine mate, we`ve all got one. However I think it is the forum rather than you as a member who COULD be on the line as you say however unlikely that may be.
Reactions: Harvest Fields
Thanks everybody for replies. 🙂
Yes, the only place I can discharge into is a rainwater gully.
It is an oil boiler job, although I suppose no different than gas.
Looks like an inline neutraliser is your best bet then.
Yes, separate according to customer and the house is only 20 year old, so I think he is correct. Just a rain water down pipe goes to it.
Really want to avoid lifting paving slabs and digging outside as too time consuming.
Looks like an inline neutraliser and piping to the gully is your best bet then .
Reactions: Best
Never fitted one yet, but am thinking that would offer an easy solution.
I have to install some oil boilers in one day if possible and those little parts to the job would take too long.
Reactions: Pickwickpick
Its amazing how much time those 'little' extra bits end up taking ***ulatively, its something I often massively underestimated when I started out. Definitely looks like fitting one will be a lot faster than lifting slabs and building a soakaway would be.
  • Agree
Reactions: Ric2013 and Best
I still underestimate the time to do the “little” jobs.
Looking now for lazy ways out where possible 😛
  • Agree
Reactions: Ric2013
This is a common problem where I have to install a condensing boiler and there is nowhere to discharge the condense.
I have an oil boiler to install in a garage and there is only a rainwater gulley close by.
To install a condense trap in the ground is too much work.
I am thinking of using something internal to neutralise the discharge first, before running it to outside.
What would you recommend?
Is there a simple solution?
Just fit a standard efficiency boiler 🙂
Just follow the boiler manufacturers instructions regarding the condense disposal bud you will then be complying to the regulations. Kop
Reactions: Best
Wish I could. Can you still source standard eff oil boilers? I haven’t asked for any. (I know they are illegal to fit normally).
Using a decent condition second hand standard eff boiler makes a lot of sense.
Can get them free, or for just a few pounds
