Guest viewing limit reached
Connect air source heat pump to 2 UFH(unused)ports on a thermal store?
View the thread, titled "Connect air source heat pump to 2 UFH(unused)ports on a thermal store?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Would it possible to connect an air source heat pump into 2 UFH (unused) ports on a thermal store? The property is heated by oil and a wood stove. I have the option to use the ports that are connected to the wood stove as using the heat pump would be a more efficient and a better priority, I think.
Reply to the thread, titled "Connect air source heat pump to 2 UFH(unused)ports on a thermal store?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Michael Donald,
ShaunCorbs,
