Connecting a Shower to a Hose - Advice Needed
View the thread, titled "Connecting a Shower to a Hose - Advice Needed" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
G
gypsymoth
Hi All
bit of a problem with washing my new motor!
Want to do it myself, live on the ground floor, but unfortunately neither my bathroom or kitchen have standing pipes onto which I can connect a shower hose and put it thru a pressure washer
On a friend's advice, I've detached the shower head from the shower cable, and then tried to put that into a hose connector - I've attached a couple of pictures to show what I mean
Unfortunately, the shower cable doesnt form a tight connection with the hose input
Given my restricted options, is there any other way to get a steady flow of water from either the cable or my square shaped taps into the hose and onto the pressure washer? it's a tough one, but hopefully there's some kind of solution
thanks L
what about nipping to the plumgers merchants explain to them what u want to do.
have u not got a plumbed in washer u could pick up water from there with a 3/4 female coupling bit of 15mm pipe and a jubilee clip. get a push fit coupling for easyness.
or Get an outside tap fitted!
paul
paul
Could do that, but thought someone on here might have a suggestion first
The washer is tightly packed in under a counter and a nightmare to get to
Outside tap would be great but again its tricky in my block. How much would a job like that normally cost?
thwe proper way is an outside tap
Drill throug wall tap into rising main and fit tap
You should see change from £100 but cant say without seeing the job
I understand what your trying to do but surely this will be a bit of a chore every time you want to use the pressure washer you have to trappe a dirty hose in the hose and connect it up.
have a look under your sink to see is the mains can be tapped into
you would not be able to control hose pipe as no valve or restgriction should be on a shower after the valve on the wall, as many of the internal washers are not made to be subjected to standingf water pressure you will knacker your shower good luck
Reply to the thread, titled "Connecting a Shower to a Hose - Advice Needed" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
gypsymoth,
leakylea,
