Connecting bath drainage to soil pipe
View the thread, titled "Connecting bath drainage to soil pipe" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi all,
I need to connect my bath drainage to my new soil pipe. I have only one spare entry to boss into the pipe at the very bottom (see photo). As the inital entry out the wall will be on a gradient I was wondering if there was a combination of elbows I can utilise to get a 90 degree vertical drop down to the entry point? As I'm using 50mm pipe I'm not sure I can fashion something on an angle, similar to boiler condensate pipe the other side.
Or would it be easier to just employ a strap boss further up the soil pipe?
Cheers. P
If you are feeling brave, get a solvent short boss from Screwfix. cut out a section, open it up and glue it in place.
I have had bad luck with straps-ons.
Get your mind out of the gutter.
Also, 50mm might be oversized for a bathroom. You could drop it to 40mm
I’ve started to use black ct1 on them haven’t had any problems since
BC are insisting on 50mm due to the distances involved. Whats your issue with a boss strap?
Reply to the thread, titled "Connecting bath drainage to soil pipe" which is posted in Boiler Advice Forum on Plumbers Forums.
kristeva,
kristeva,
