Aug 30, 2009
25
Hi all,
I'm looking to connect a new plastic soil system (Marley) to the old cast iron soil at driveway level.
Does anyone know the correct fitting to do this? I came across this one on the Marley website (the SA42) Catalogue - Marley Plumbing & Drainage but I really wanted a grey fitting to match the rest of the installation (the SA42 is only available in black).
The system I'm using is push-fit.
Thanks in advance,
Tony.
Thanks for that, just what I'm looking for!
It is if you want a nice restriction and potential blocking point,if you use best put a rodding eye close by 😉
Why not do in black,looks a lot nicer and just to be a manic depressive would use solvent weld or if you must use push fit,make sure all push fit fitting supported well
even if using gray would use a black time saver to connect,or if cast not to far in ground ,connect straight to clay
