G
GB1309
Shaun kindly recommended:
"Altecnic - 3/4" MBSP x 3/4" MBSP - Prescal Series 535 Dial Up Pressure Reducing Valve With Presure Gauge - 535051
Altecnic - 3/4" FBSP x 3/4" FBSP - Y Pattern Strainer - AI-500022
and a good pressure reducing valve shouldn't change/lower the flow"
And it looks a good bet but as I have 15mm domestic copper pipe I have sorted Prescal 533841 as an easy fit for about £35 delivered. They are fitted with a strainer so no need for second item listed above?
The 3/4 valve may have a better flow rate but I am pushed for space and the threaded ends will be hard to accommodate.
Is it likely the 533841 will sort me out without significant flow rate drop when regulating from 6 down to 3 or 4 bar?
Many thanks for any help.
Graham.​
and instead of the threaded ends use a blank tap connector, and always worth fitting a strainer
but the 533841 will be ok[/QUOTE]
Excellent Shaun thanks. I'll do just that. I presume I can fit the 500022 strainer in the line using the input threaded connector on the 535041? I have the standard domestic blue plastic rising main to stop tap (which I also intend to replace).
As for the Telford input group, I think they have supplied a better quality reducer than those I have used downstairs so I hope its OK. I think there is a pressure relief valve on top anyway which would go if the input pressure rose above 3 bar.....I hope. It was only serviced a month ago and all was well.
Thanks again,
Graham.
Thanks again,
Graham.
yes thats why i linked them and
you can use either a blank tap connector or a 1/2 female iron to 15mm
and your replacing your stop tap?
and yes if pressure rises too much it will start/open
Well this has proved to be a well useful forum to join.:yes:
I'll get the bits and work out a new layout to accommodate it all behind the sink unit.
Thanks again Shaun.
Graham.
Thanks again Shaun.
Graham.
any problems please come back or when your done and everything working just let us know 🙂
Fitted the Altecnic Prescal 535 regulator/pressure reducer today with a strainer. It works very well and the "on stream" throughput only sees the pressure on the downstream side drop by approx 1/2 bar which is far better than the cheaper Mickey Mouse unit I had in before. I've set it to 3.5Bar. I have taken before and after photos but am reticent about posting them in front of professionals although I am rather proud of the 180 degree loop I did with the bending spring around our pressure cooker.. Anyway, lesson learned: it's a good idea to seek advice and then spend money on proper kit.
Thanks for the advice. Graham.
Here they are. The L/H blue key valve feeds the O/S tap as I wanted full bore out there.
The extravagant loop is to try and minimise elbows and thus noise.
Anyway, I'm pleased with the outcome.
Graham.
Thanks Shaun. After spending most of the day in the sink unit cupboard I was nearly round the bend myself.
Plumbing is a young mans game I've decided.
Graham.
There is no man alive who can find a comfortable way to work under a kitchen sink.
I charge more now when doing kitchen sinks as I get so fed up of destroying my neck and back.
Actually, for the first time i used a bean bag. It was a surprising success as it formed up over the front from the floor and helped me to lean in pretty well supported. It'll morph to suit your position.
I wonder what sort of response I'd have received if I'd started a string on "bean bags as a plumbers aid".
Did I really write this?:blush2:
