K
kprida
We recently had a leak from the pressure relief valve on the inlet control set. It appears this was due to the expansion vessel needing a recharge. This was re-pressurised back to 3bar, the relief valve continued to leak and so was replaced. Now when the hot water is on, once its up to temperatures (the cold feed pipe gets warm) the new pressure relief value is leaking (dripping).
The pressure relief valve was replaced with a 3bar item. The expansion vessel is set to 3bar, the pressure reducing valve is set to 3bar, and the new relief valve is 3bar. In my head that means the relief valve will open very quickly at the slighest variance? I found the manual for the hot water tank (Range Tribune HE) and it mentions a 6bar relief valve. Does it sound like the plumber has fitted the wrong valve?
Thanks.
Thanks.
