Called out to a dripping overflow.
Turn out to be a small warmflow unvented cylinder. Up in the loft.
No insulation.
No 2 port valve.
Cylinder stat not wired.
Discharge tundish on top of a pulled bend. 22mm copper disappears down towards bathroom.
Bloke then tells me back wall is soaked where its been dripping. So goes outside to see a plastic overflow dribbling away 3 metres up the wall.
Then to top it all its being ran off a solid fuel back burner.
Fitted by a builder 2 years ago.
I've e-mailed customer with list of faults and he wants me to put it right.
The choices I gave him were
1. Break the solid fuel with a plate heat exchanger to separate circuits.
2. Vented cylinder.
3. External combi, which he is keen on.
My main worry is what do I do with regard the current install. Phone building control? All the cylinders paperwork was stuffed behind it, wasn't notified.
Basically what do I do to cover my arse?
All replies gratefully received.
No insulation.
No 2 port valve.
2. Vented cylinder.
