Guest viewing limit reached
Descaling coil in domestic hot water copper cylinder
View the thread, titled "Descaling coil in domestic hot water copper cylinder" which is posted in Boiler Advice Forum on UK Plumbers Forums.
M
Momo
25 year old dhwc doesnt have scale at the bottom but coil does. I can easily empty it, fill it with vinegar from the washing machine hot water outlet with a submersible pump, turn on the boiler & heat it up over a couple of days before emptying it through the main body(not spout) of bath tap.
can this damage the joints & cause a leak?
i dont want to use commercial descalers such as DS3 as it would b much more difficult in many ways(handling, introducing it, rinsing...)
thanks very much for any help/views
There is a way of descaling it properly in a day but it will require heavy duty products. And the knowledge of how to handle them correctly plus £1100 worth of equipment.
i am yet to find a natural or domestic product that will even scratch the surface of limescale. I descale a lot of thermal stores but not a cylinder for the cost and time of descaling a cylinder it's better to replace then repair
Thanx for your resposes.
the vinegar will cost about £40. A new cylinder is around £300! Plus fitting.....
vinegar works very well in our kettle but perhaps it will b different in a cylinder?
maybe its impossible to b sure whether it will damage seals & cause leakage which is my main worry?
thanx again
Reply to the thread, titled "Descaling coil in domestic hot water copper cylinder" which is posted in Boiler Advice Forum on Plumbers Forums.
Momo,
Momo,
