DFE fire lightheaded cause??
View the thread, titled "DFE fire lightheaded cause??" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
aligorgon
Hi guys am new to the forum, I am a Pipefitter turned Service engineer, with UPA1A and UPA1B gas quals.
I have also got my gas fires, cookers etc but don't work on these much as I mainly work on boilers and water heaters in commercial premises.
I have at my home a DFE fire which I hardly use due to the cost of running it. However, when I do put it on I can't help feeling a little light headed.
I have a CO detector in the room which picks up nothing, and have performed a FGA and CO room safety check. OK i get a bit of CO when I stick the FG probe almost in the flame but nothing if I move it say 5 inches above the flame and all around the surrounding area.
The oxygen level in the room never drops below 20.8 %.
Spillage testing and flue flow are fine and i don't get any spillage or back flow, and a i get no drop whatsoever doing a tightness test.
I am doing all these tests with all windows and doors shut.
Am at a bit of a loss and wondering if anyone has had a similar issue. My missus reckons its in my head as I fitted the fire and i'm paranoid, but we are looking to rent the house out soon and even though i have completed the landlord cert. I don't want to rent the property without finding a solution or disconnecting the fire.
yes, the only descrepancy i could find was the inlet pressure... the fire asks for 20mbar +- 1 whereas I have 24mbar at the inlet, but surely i would be getting more CO on my FGA if this was that critical...?
You need to check the heat input aswell as burner pressure, one up one down indicates injector problem, both up or down is back from injector, if your flues pulling fine though you shouldn't be getting lightheaded
you need a air vent of 100 cm2 for d f e fires none for living flame up to 7 kw because in theory this is catered for with adventageous air from air gaps in the fabric of the building but cant help feeling in these days of double glazing and draught excluders this reg couldnt do with a review all your checks are correct and readings are fine but if you have it in your head that a problem exists then cap it off after prolonged lack of use you do get a strange smell from these things sometimes for a spell due to the dust that settles on them awfully wastefull anyway less than 50% efficiency just nice to look at on a winters evening
I'm with Simon if you're going to rent the property, definitely much safer that way.
thanks for all the replies..
no mike i haven't checked the gas rate to be honest the data badge is that faded I couldn't read what it is supposed to be, i'll have a search online for it. Its a archtray mc ng2 burner.
If it is not used for long periods at a time and checks out ok when it is it is, usually the smell is from settled dust burning off.
As said, if you rent the house out cut it off. No need to remove it. Just cap the supply.
Yes cap it off if your unsure.
Tenants who do not know this kind of fire will probably go berserk when they find out how much gas it uses. I do hope you have alternative heat sources?
Another point is tenant abuse. I remember fitting one of these in a pub when they first came out. Went back the next day and found the public had been using it like an ordinary fire it was full of *** ends and *** packets.
I think BG refuse to fit them now and have refused for quite a few years. Must admit though they are nice to look at. And I would certainly make sure there is bags of ventilation in the room even going over the top of the manufacturers recommendations.
Shhh! But why don't you adjust the governor yourself?
And no, they don't charge and should arrive within a hour or so of callout.
That will be inlet working pressure. Try the same with fire lit. Sure you will get 19-21 mbar then
Reply to the thread, titled "DFE fire lightheaded cause??" which is posted in UK Plumbers Forums on Plumbers Forums.
aligorgon,
MDS PLUMBING,
