DIYer - need help with toilet pipe air-valve install
View the thread, titled "DIYer - need help with toilet pipe air-valve install" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
New to the forum - hoping to get some help here.
I am rerouting my toilet to have the pipe work hidden in the eaves.
Bath/shower/basin waste connects to the toilet drain via Barco Bos.
I need help with the air vent.
- Do I need one for toilet, and another for shower/bath/basin waste?
- Do I need one for each bath, basin and shower?
Where is the best location for the air valve (or valves)?
Many thanks for your help.
Is the stack vented to outside air or is there another stack on your system that vents?
What is a Barco Bos?
What size is the waste float picking up the bath & shower & how long is the run to the bath?
Gents, thanks for your replies.
Yes, perhaps not the most logical approach but I'd like to try before giving up. This will make space available that was previously unavailable.
The bos (or boss) connects the 40mm on to the 4 in pipe.
It is not going uphill - there is a drop of about 450mm from toilet outlet to outside stack. Is this sufficient?
The stack can be vented outside, but will it take care of the basin/bath/shower pipe venting?
Adding rodding point to the planning.
It’s more the proximity of the bends. Every turn causes resistance and friction to the nasties trying to run away. Sometimes the easy option isn’t the right one
The bath on emptying will pull the seal out of the shower. Each appliance should each have its own waste ideally to the stack and not all joined up.
See if you can substitute the 3 x middle 90° for 2 x 45°'s
If its already an internal stack take it high and fit a durgo if it's external take it past the highest outlet inside
Not all outlets / sanitaryware need a vent, unless it's pulling a trap ect..
If you want to play it safe fit anti-syphon trap under bath and basin there not that much dearer than a normal trap
The 40mm waste pipe will pull any water filled traps on the all the fittings when the bath is drained Part H of the building regs sets out the maximum runs for single runs to single fittings once you start combining them then you need to increase the waste pipe size or add an anti-siphon pipe or mini AAAV or replace the water filled traps with waterless traps.
The stack should be ventilated, the branch to the WC doesn't have to be but I would be tempted to run a 50mm anti picking up the WC & the bath (40 or even 32mm) if at all possible, run above overspill level of the pan & connected back into the dry part of the stack (vent pipe). In that way no mechanical devices would be required.
Medium radius bends are fine so long as the float is installed with the correct falls (18 - 90mm per M) de-bur the pipes & you will not have any problems.
https://assets.publishing.service.g...achment_data/file/442889/BR_PDF_AD_H_2015.pdf
Thank you all for your replies - very helpful stuff.
Ok, so install anti-syphon traps on shower/bath/basins.
AAV or Durgo on 40mm pipe. Inside eaves ok? see diagram.
AAV/Durgo not required for toilet, but better if it has it? Or definitely required? Or not needed at all?
I'll attempt to use 2 x 45° bends instead of the first 90.
Did I capture everything? Thanks again everyone.
@ChrisWatkins - many thanks, very helpful.
Is this what you mean?
No, you don't need & probably shouldn't have a "Durgo" on the main stack, can't terminate to atmosphere ? if it can then the loop is find but not essential it is more to try to anti the bath run so it will not self-syphon when discharged. Otherwise couldn't you run it separately along the eaves to connect directly to the stack?
Remember this work is covered by Building Control & you should be talking to them.
Please don't use anti-vac traps you may well live to regret it.
Try this type of trap = Sanitary waste valve in bathroom applications
Thanks Chris,
With a waterless trap I can now reroute the bath and connect directly to the toilet's 4 in. (See diagram) because it can go above joists.
This ok?
https://www.NoLinkingToThis/p/osma-...qAosAERuxAzb8d-yeEAaAmbpEALw_wcB&gclsrc=aw.ds
About the AAV - should it go on the 4 in behind the toilet, or the shower/basin 1.5 in?
Reply to the thread, titled "DIYer - need help with toilet pipe air-valve install" which is posted in DIY Plumbing Advice on Plumbers Forums.
pc__upf,
pc__upf,
