Sep 25, 2023
53
northumberland
DIY or Homeowner
I think it is a gas fitting, although it is used in an old LNER station lamp post.
The reducer female part measures 15/16" the male part measures 1 5/16" approximately.
It is stamped WALWORTH MADE IN THE USA
It also fits the lamp shade but is actually from the post to support a braced cantilever piece of conduit.
Hard to say without seeing a tape on it but looks bsp/npt so might be in look with a 1”x3/4 reducing bush
Thanks Shaun
I obtained one and it seems compatible and fine for my purposes which isn't plumbing but restoration.
It's a tapered thread so not sure how much to tighten safely
As it's American it will be American National Standard Pipe Threads (ANSI/ASME B1.20.1) known as NPT, not the BSP you have. They are a different thread angle 60degrees not 55degrees and have pointed rather than rounded angles.
They will as you have discovered fit to a certain extent but I wouldn't rely on the seal. In a very low pressure gas fitting you are probably ok just using Loctite55 thread sealing cord, but should really be buying the correct NPT hex head bush.
The correct size NPT threaded bush is probably available on eBay. Or use two adapters NPT-BSP/BSP-NPT
Of course the fact that it's an American fitting on an LNER lamp may well suggest that it's not the original part and it should in fact be BSP
