Will this all I need and it will work?
thanks again Shaun very much appreciate your time and patience.
Yeah the Honeywell worked fine I only replaced it caused it looked dated. The temperature in the house ATM is 25 degree centigrade I override it to 30 the small flame appeared on the display and it should then fire the boiler up? I did read this programmer and all other thermostatic programmers that are made now have an intelligents built into it. I'm thinking because I
The house is already very warm it won't fire the boiler due to the fact that it's too warm and this must be the intelligents kicking which makes it be energy effiencency? Would I be correct?
What if I swap wires around?
What is the worst it can do if it doesn't work? Could it blow the fuse?
Should it matter if the red sleeving is biting down on the screw rather than the copper wire in the connecter block on the Drayton programmer?
Yeah shaun I've done it that way. From your experience What could be the problem?
Reply to the thread, titled "Drayton Digistat+ 3 hard wire problem" which is posted in UK Plumbers Forums on Plumbers Forums.
