Guest viewing is limited
dunsley neutraliser
View the thread, titled "dunsley neutraliser" which is posted in UK Plumbers Forums on UK Plumbers Forums.
hi there everyone
has anyone out there had experience with a dunsley neutralizer?
i got called out to a fairly large house with a wood burner and a heat only gas boiler, both going into the neutralizer at the cylinder. each boiler seems to have a pump on the return.
the fill goes into the wood burner which i thought was strange.
anyway the initial problem was that there was no heat in the rads in the extension.
all the pipework that i can see is in 15 so thats not great. after balancing i have got heat in there but nothing spectacular.
just wondering if the neutralizer could have anything to do with it and also, why does the cold feed go all the way to the wood burner.
any advice please?
cheers and happy new year!
If its genuine and you're still stuck after reading the instructions, give them a bell and they may be able to advise.
Reply to the thread, titled "dunsley neutraliser" which is posted in UK Plumbers Forums on Plumbers Forums.
Jcrabb,
wheeto,
