Efficient way to heat radiators and unvented cylinder
View the thread, titled "Efficient way to heat radiators and unvented cylinder" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
I have a gas boiler heating radiators and also heating an unvented cylinder.
I have a Honeywell programmer which has the water heating up 1.5 hours early morning 30 mins midday and 2 hours evening
The heating is on a couple of times a day.
With the energy prices I am wanted to ask if hearing the water and hearing the radiators at the same time would save money or if would still use as much energy as running separately?
Thank you
Unlikely to make any difference. If you really want to be sure, use a pipe thermometer to measure the temperature of the the return to the boiler in each mode. Choose the mode that gives the lower return temperature.
Reply to the thread, titled "Efficient way to heat radiators and unvented cylinder" which is posted in DIY Plumbing Advice on Plumbers Forums.
Douglas2404,
ShaunCorbs,
