Electric shower
View the thread, titled "Electric shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
mfgs
Does anyone have a recommendation for a decent reliable electric shower?
I don't normally fit them so don't have a great deal of experience in knowing what is best. Budget is about £120 max for the shower
While on the subject of electric showers, does anyone know if there is a direct replacement for this shower Mira Essentials 8.5 J89K? I contacted Mira and all the showers they make these days the electric and supply are the wrong way round. So old was water top left and electric middle left or vice versa
Mira Play or Go will fit straight on
I don't know that Mira model, but I guess Mira would suggest only their own models as replacements.
Really not worth doing any damage just to move pipe & cable.
I recently replaced a couple of Mira showers that had the pipe & cable on left, with Redring Expressions model. It comes in a 8.5 or 9.5 kw. It has water or wiring connection either side.
The redring seems like a nice shower but LTD places sell them and not cheap on their site. Do you get them cheaper from your merchants
Cos you spoke to somebody manning a phone wcgaf
Copy and pasted...Good Afternoon,
Thank you for your e-mail.
We don't have any that would an direct replacement for the older Mira Essentials.
The J89K had inlet connections for water in the top left whereas most of our current range are middle left so it would require some adjustment, The electrical connections are also middle left on the older essentials whereas the new ones are top left so again would require work.
Best options would be the Mira Jump/Sprint Multifit 8.5kw as the unit slightly larger but as mention connections would require adjustment.
The Redring Expressions Revive is under £120 inc vat for the 9.5kw.
Then there is an almost identical model that only difference is a cheap sort of rail kit and hasn't a seperate on/off button, - for only £64 inc vat.
I always hope the cable isn't plastered into the wall, or not accessible and too short.
I don't mind having to do a bit of manovering or altering the pipe and cable, but I prefer to only ever remove or replace tiles if last resort.
I wouldn't recommend the new Redring showers as being easy for the installer to connect. Frankly they are a bit poor.
Redring are mainly sold by electrical merchants round this way. No plumbers merchant i know stock them but they could probably get you one.
Screwfix do them. Plus, as you say, electrical places here, but also some merchants stock them.
I found Redring very reliable for years, but these latest models are completely different works, so it is a gamble. Bristan or Triton might be better for all I know, and certainly can't be any harder to fit
Its a few years since i fitted a Redring shower. Grahams used to sell them but thats a few years back.
I fitted Redring showers on rentals and have only had one (a basic £60 model) needing replaced and some of the better models (Expressions) needing a repair. But Redring in their wisdom have renewed their showers, so now I don't know what is reliable
I have contacted Mira and they have said my best option would be a jump but it would still need moving cable and pipe. I didn't want to get into removing tiles etc
The jump has electrics both sides. The water connection is on the left hand side but there is a track for running a pipe around inside. It's also quite a big beast but I haven't had one that hasn't covered the existing holes etc.
I fit around 5 Mira jumps a week found them to be a reliable shower although not very powerful
As in the 8.5kw model but it is an ideal replacement for most showers as the footprint is larger than most showers so covers any broken tiles.
The water inlet is on the left but it does come supplied with a section of pre-cut and bent 15mm copper with two brass elbows so retro fits everything (you have to ask or they won't give you the kit
Electrics on left and right covering all bases
The triton T80z used to be the shower of choice but had too many failures
So we only fit the jump, sport and advance.
The rail kit, I recall, is poor though.
Aye its pretty shyt for a Mira compared to what they used to be but they are all getting a bit like that.
For years the rails put me off Tritons and i would price mainly on Miras at twice the price and no doubt lost a lot of jobs over it (not that i cared much) but as i've gotten older i can't see it from my house so don't care anymore.
All i ask these days is cheap or not so cheap. Their choice.
Reply to the thread, titled "Electric shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
mfgs,
mutley racers,
